Info on the acer keyboard. How to use alt and ctrl keys as the popups say.It doesn"t seem to do anything. thank you
    Scholar:
  • 125 Answers
Your question is a bit unclear, but..
ctl and alt keys are used together with other keys.
You must press and hold them first, the press another key, then let go of both. In windows, pressing alt should at least activate the menu bar.
Sometimes you may not see the result, even if it works. (For example, ctl-c copies highlighted text, but you won't see the result unless you paste it in an application with ctl-v)
Also, the key combination must have a defined function in the active application.
Posted on May 13, 2008
My CTRL "WINDOWS" and ALT
Check right click button also, if it is not working, it means the bottom row of your key board has fault. Open your keyboard and clean it.
Aug 27, 2011 | Dell 0Y3740 Keyboard
Tip
Win shortcuts
Windows key + E = Explorer<br />ALT + Tab = Switch between windows<br />ALT, Space, X = Maximize window<br />CTRL + Shift + Esc = Task Manager<br />Windows key + Break = System properties<br />Windows key + F = Search<br />Windows key + D = Hide/Display all windows<br />CTRL + C = copy<br />CTRL + X = cut<br />CTRL + V = paste<br />Also don't forget about the "Right-click" key next to the right Windows key on your keyboard. Using the arrows and that key can get just about anything done once you've opened up any program.
on Apr 12, 2011 | Computers & Internet
Can't use PrintScreen key on Logitech's "Cordless Internet Pro" keyboard. Key is on upper right of keyboard with "Prt Scr" above "SysRq" on the same key. I've...
It's what you do AFTER PrtScr that matters.
Basically the key takes a snapshot of the screen and stores it on the Clipboard. Next PASTE it into an application like Paint and Print from there. Or paste into a document you are working on that requires a screen clip (after editing it, if needed).
Rate me 4 stars is this helps!
Oct 25, 2017 | Logitech 967437-0403 Keyboard
What are the four main keys of the keyboard
There is't really such a thing as four main keys. Ctrl, Alt, Shift and esc/del are used a lot for shortcuts.
Comment back to clarrify what your talking about if this doesn't not answer your question.
Aug 09, 2011 | Acer NSK8458AN Keyboard
Ctrl + Alt + Arrow Key DOWN turns video flipped upside down. I have some edistors that use this shortcut for code replication. So I would like to disabled this "video flip feature" orat least...
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key. Restore by pressing Ctrl-Alt plus the up arrow key. ALSO To change the display from portrait to landscape Press Ctrl-Alt plus a left or right arrow key. Some computers do not have this function.
Jun 01, 2011 | ASUS Eee 4G Notebook
The print screen key does not seem to work. Is there a "trick" to it?
yes it must be used in combo with CTRL ALT and sometimes the windows key, then you must past the image to a paint or word document.
Mar 21, 2011 | Sunbeam Acrylic Lite-Up Slim Keyboard...
The @ symbol is on the wrong key it is on " key ,
Hold down the ALT(ernate) GR(aphic) key (to the right of the SPACE BAR).
Hold down the SHIFT key.
Press the '@' key.
Release the '@' key.
Release the SHIFT key.
Release the ALT GR key.
Feb 26, 2011 | Acer NSK8458AN Keyboard
Can't type anything without weird things happening the \'p\' prints,
hi, check that Sticky-keys arent turned on.
to toggle Sticky-keys on and off, press the shift key 5 times fast, then either Disable the sticky-keys tickbox, or click Settings for more configuration settings.
when sticky-keys are enabled, you can press shift and release, and the shift key is still enabled. this also goes for Alt, and CTRL.
so if it is enabled, pressing P will attempt to be Ctrl-P - which is print.
Sep 10, 2009 | Acer NSK8458AN Keyboard
Switching monitors connecting an external monitor
For my Acer 2300.. found in Control Panel an icon for the actuall display card and within there discover Ctrl, Alt -F1 for external, Ctrl Alt -F3 to go back to the notebook monitor. Hope that can help someone.
May 21, 2009 | Acer TravelMate 2300 Notebook
Desktop is dispalyed horizontal on monitor
The Ctrl-alt direction key sequence is supposed to be used for changing your workspace. On my computer at work it changes the screen orientation Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
(If that doesn’t work, try Ctrl-Shift-R)
May 31, 2008 | Acer X193W LCD Monitor
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
