Question about Samsung LNT4066F 40 in. LCD Television
How do I remove the base of the TV model # LNT4061FX so that I can hang on the wall?
2 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: I have recently bought a Samsung SM2033HD TV and
Your tv is not fully VESA compliant. You cannot remove the collar. There are mounts available that grip the screen instead of screwing into the back. This type will look better.
Posted on Jan 10, 2010
How can i get the stand off of the tv to hang on the wall?
Before detaching the stand, unplug the AC cord from the AC INPUT terminal. Before performing work spread cushioning over the base area to lay the TV on. This will prevent it from being damaged.
With the hex key that came with the television stand remove the four screws from the bottom back of the television and remove the stand.
If you also wish to remove the post from the stand base unit you can remove the four screws that attach them.
Jan 03, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How to remove the base plate so i can mount it on the wall
Most LCDs have anywhere from 4 to 6 screws holding base on. Lay it on a table on its face with base hanging over the edge, using a towel or blanket so you don't scratch it. The screws should be just above where the base goes into it. remove them and the base should pull right out. Good luck!
Feb 23, 2010 | LG 47LG60 LCD TV
How do you remove the stand of a grundig gu22wdvd3 so we can put it on a wall bracket ; it has the holes for a bracket to fix into.
First remove the two screws from the underside of the base, pull the oval base clear from the stem. This will reveal two screws within the stem, remove these and the four on the back of the stem. Job done, hang enjoy.
Nov 15, 2009 | Grundig GU22DVDPX 22 in. LCD TV
I want to hank my toshiba 42-95plasma tv on the
Toshiba has about six screws holding the base legs on remove them and pull the base straight down till the legs come out all the way
Jul 25, 2009 | Televison & Video
We can't figure out how to remove the base on our new 50" Sanyo Plasma TV so we can hang it on the wall...HELP!
look at the rear of the tv there are four phillips head screws holding the base on unscrew them and lift the base off
Apr 15, 2009 | Sanyo DP50747 50 in. Plasma TV
Trying to take the base off my son's 42 inch olevia 542-b12
There are 16 phillips head screws on the back of the TV above the base, remove all of them and the base just falls out.
Dec 31, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Samsung LNT4061fx does not turn on
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts.
Good Luck, big IRISH.
Nov 20, 2008 | Samsung TXG2547 25" TV
I want to take off the base of my flat screen tv.
lay tv down on a flat soft surface remove 4 philips screws on back on either side of signal brd inputs base will pull out of bottom
Oct 15, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Akai Plasma PDP42Z5TA - removing base stand
The base removes with the support arms that rise the height of the tv. remove all the screws from the back of the support arms and the base will slide out with the arms. you will need the holes open to mount to the wall mount
Jun 16, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Taking the base off
Please tell me what TV it is and give me a model number, once i know that I can be of easy help.
Have a great day
Jun 04, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung LNT4066F 40 in. LCD Television Logo
66 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
