Question about Dell OptiPlex GX270 PC Desktop
Ticking sound My pc won't boot. Black screen. I have removed the video card, ram and disconnected ide hdd, cdrom and floppy and it's still the same. Sounds like it's coming from onboard speaker.
  • monty1953 May 13, 2008
    It's an Optiplex GX270. It's a ticking sound not a beep. One tick every second consistantly and never stops until you power off.
  • duggieburger Jan 27, 2009
    I have the same ticking sound.. its coming from the small speaker on the mother board.. just a blank screen on power up.. goes right into this ticking sound.. Not beeps so no beep codes.. never stops.. ticks about every second..
    Novelist:
  • 166 Answers
Does the noise sound like this? Click Shhhhhp Click Shhhhp repeating in a ryhthmic fashion? If it does and you have an IBM/Hitatchi Deskstar hard drive then you have what is known as the "click of death" meaning that the hard drive has bit the dust. I have never been able to recover from this on those drives.
If this is not it then look at this.
With no video output and being that the Optiplex GX270 was in the run of "bad capacitor" mobos you may have blown capacitors on your motherboard. Open the case and look at all of the capacitors that have a "+" or "X" on them. They should be perfectly flat and not bulged at the top or leaking any stuff. DELL, along with other PC manufacturers got bit by a cheap company that sold cheap capacitors that were faultily manufactured. If any of them are bad then your computer will not work right.
Posted on Mar 11, 2009
  • computerscot Mar 11, 2009
    Capacitors look like little tiny soda cans. Just look at the top of them. They should be flat.
  • 43 Answers
U must tell me that the which type of sound is this. eg.- 1beep, 2beep, 3beep, 1long 1short or 1 long.
and ur motherboard and processor's name.................
Posted on May 13, 2008
Continuous short beep when start... no boot up, already change the power supply and few rams for testing, but no change. should the motherborad or cpu fail?
processor failure does not produce beeping sounds, are you sure that your extra rams are working? try to change the video card if you have the removable one. then if you're using the built in video card, try removing the sound card and modem cards or lan cards.beeping sounds is only for ram errors and any other hardware but not limited to motherboards. by the way try to clean the slot for rams, video cards and others. this would help.
Jul 12, 2011 | Acer Computers & Internet
My dell optiplex doesn't boot... but i can hear the sound (not beeping) and the spinning hard disk. Nothing is in the screen. I tried removing and exchanging RAM but didn't work.
The possible causes that can cause a PC not to boot are:
  1. Defective RAM
  2. Defective Video Card
  3. Defective HDD
  4. BIOS battery
For the RAM and for the video card, check if they are well clipped on the motherboard. Try removing and replacing them.
As for the HDD, check the SATA/IDE cables.
If all the steps above seems to be ok, try changing the BIOS battery found on your motherboard.(Note this will reset your BIOS settings).
Hope this helps you !!
May 10, 2011 | Dell OptiPlex 360 Desktop Computer
ASUS M2N68-AM SE2 GeForce 7025 Socket AM2+ MB built system. Works great with Sata hard drive. Removed my older 500GB IDE hard drive and CDROM from old PC. When i try to put both, or either 1 into to IDE...
Try to go into the bios and set the first boot device as your sata hdd. There will be a option in boot section of the cmos setup where the hdd drive order will be mentioned. If PATA is shown first press enter in the option select SATA and press enter save and exit changes things should go on fine.
Also check your pata hdd and cdrom specific jumper setting. For more help post your HDD model and make and cdrom model and the bios type
Dec 01, 2009 | Computers & Internet
WinXp wont boot after the initial installation
See if it will boot off the XP CD.If it does I would think you have a corrupt boot sector. Installing windows again should fix it if it is.
Dec 14, 2008 | ASUS P4SDX Motherboard
Start up
Try removing all IDE/CDROM/Floppy devices from the machine. Then remove extra PCI cards like modems and sound cards (if you have any). Then enter the bios, and reset the bios to it's defaults, and reboot. If that gets to the looking for OS section, then plug each device back in one at a time. Start with the most important devices like the hard drive and Cdrom drive. Then after testing that it still tries to load the OS after each device, you'll identify which one is preventing startup.
Steven
Sep 17, 2008 | ASUS A8N-SLI Deluxe Motherboard
Boot sequence problem
try booting to DOS screen only by inserting a boot-able floppy disc (I use Win ME disc at this point although my system is also Win XP). Then select "boot with CD-ROM driver". It will detect your CDROM drive and assign a letter. Now insert the CD and boot from there. I have done this sequence many times with no problems.
Jul 13, 2007 | Compaq Armada E500 Notebook
Motherboard is dead
remove the RAM. boot minimal only (floppy). get to BIOS screen. reset to factory default. try again with boot floppy. if ok, re-install RAM and repeat
May 31, 2007 | Intel SuperMicro SUPER Motherboard - 810...
Dell OptiPlex GX270 PC Desktop Logo
222 people viewed this question
Alun Cox
