Question about Home
One of the recessed spotlights in our bathroom is hanging down as it appears the circular spring clip has been lost. Where can I get a replacement clip and how does it fit?
    Problem Solver:
  • 12 Answers
This is a good time to update your trim rings. These are really cheap ( less than $10 ea.) and can be found at any home improvement store. They come with the clips attached to the rings. Take your old one with you so you'll be sure they match the existing can lights in place. There is a slight variation in some of the clips depending on manufacturer.
Posted on Oct 04, 2010
Testimonial: "Thanks for your help. We have managed to source a replacement spring clip which has now been fitted. Problem solved! "
How to remove piston from connecting rod
Depends on the make and model, but you haven't stated. Usuallt they have a small cir-clip or circular wire clip that sits in a recess on the piston where the sleeve for the con rod joins the piston.
Apr 10, 2016 | Garden
How do i get the cv joint off the trans 2003 ford escape
The shaft end inside the transmission should only be held in place by a circular spring clip in a recess at the end of the spline shaft. Even prying pressure on BOTH sides of the housing against transmission should release it.
Jul 03, 2014 | 2003 Ford Escape
Bathroom tile
If I need to replace a broken recessed soap dish in the shower then I would definitely contact with a professional as they can fix this problem very easily.
Jul 16, 2013 | Home
How do I replace the blade guard on a Dewalt DC390K saw
Remove the clip behind the back blade flange holding it on to the housing and lift it up of the return spring, replace the opposite way remembering to relocate the return spring. Make sure you get the model number correct as the 390 and 390k are different.
Dec 31, 2012 | Heavy Duty DeWalt 18V 6 12" Circular Saw...
The blade on my Mac Allister circular saw spins on the spindle when not powered. It appears the spindle nut doesn't tighten on to the blade enough. Should there be a washer either side of the blad
Yes, there must be a washer between the blade and the nut. On many saws this washer has a D-shaped hole to match a flat spot on the shaft. The back-side of this washer usually has a recess so that when the bolt or nut is tightened down it presses down on the saw blade, not the end of the shaft. Sometimes these washers are of the beveled spring type. Good luck!
Nov 06, 2012 | Saws
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
Broan square bathroom fan light combo, no screws - how do I change the bulb?
The entire vent panel and light lens is held up against the ceiling by two spring clips mounted on 2 sides of the panel.
To find which two sides they are one, (they're opposite of each other), just pull on one side with your finger tips and when you see the wire spring clips, just pull down on the two sides where they are so you can get to the bulb socket.
The panel will pull down about 5-6 inches you can then either get at the light bulb, or lift up the light lens to clean it and get the bulb out.
Be sure to replace the bulb with the proper wattage bulb so you don't overheat and melt the lens in the unit.
When you're done, all you do is push up gently on each side to get the panel back in place. You might have to squeeze the wire retaining clips to get them back in, but they'll go back OK.
If you want to completely remove the cover panel, you just squeeze the retaining wire clips nearest the fan enclosure on each side and that will let you take it all the way off for cleaning, etc.
Hope you find this Very Helpful and best regards!
Sep 24, 2009 | Broan-NuTone Broan QTXE150FL Bathroom...
How do you remove the cover on a recessed light to change bulb?
Most "can lights" have a spring clip on either side of the cover and you simply pull down on it. To completely remove it you push together the clips, and pull them through the slots.
Aug 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Home Logo
330 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
