Question about Honeywell Programmable Thermostat Heater
I have a problem with my Honeywell non-programable thermostat T8411R 1028. Screen is blank + AC won't come on. Home Depot and Lowe's do not carry this model and after looking online all I get is part is obsolete. In theory if I can find one of the exact model shouldn't I just be able to snap it into the footprint (plate) left on wall by last one (with all wiring left as is)?
  • 674 Answers
This thermostat is powered by the tranformer in the air handler. Before you change the thermostat, make sure the transformer is working. First check the circuit breaker for the air handler. If you have or can get a voltmeter, check for power on the transformer primary (120vac) and the output from the secondary (24vac). If you can't get a voltmeter then go to the thermostat and remove the face from the base plate. Use a piece of wire to jump power between the R and G terminals. The indoor fan should come on if the transformer is good. If it doesn't come on the transformer needs to be replaced. You are right about just replacing the face. It should work with the base that is already on the wall.
Posted on Sep 07, 2010
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
What do I do My Honeywell thermostat T8411R is not working. Its display is dark
The thermostat wire may have and break and not getting power. Honeywell Customer Assistance at 1-800-468-1502
May 08, 2014 | Heating & Cooling
I am replacing an T8411R with RTHL3550 and I have the following wires. Original vs New G=G,R=R,Y=Y,O=O......? I have a W2 and an E wire that go into different screws on original but no seperate terminal...
C is actually a power wire; it provides power for some programmable thermostats. You don't have to connect it on the new thermostat; cover the end with electrical tape to avoid it causing a short. (If you keep that wire accessible, it will be nice for someone who wants to use another programmable thermostat. The ones which can talk to wireless networks require this wire.)
Do you have a heat pump? That is the only time a thermostat uses an E wire.
The W2 wire should go to AUX (third screw terminal from the left) and the E wire should go to E (second screw terminal from the left). See page 25 (27 on the pdf) of the Quick Installation manual for the RTHL3550. This manual is available from Honeywell at http://yourhome.honeywell.com/home/Products/Thermostats/Digital-Non-Programmable/RTHL3550D.htm .
I hope this helps.
Nov 03, 2013 | Heating & Cooling
Hooking up a new thermostat honeywell rth7600 from a honeywell t8411r. we hooked up the wires as shown in the installation manual- we have fan but no cold air blowing out or it feels like the heat is...
apparently who ever did the wiring installation did not use the Proper color coding when they did the install. Now you must trace the wiring to the appliance and wire accordingly.
Oct 10, 2013 | Honeywell Programmable Thermostat Heater
Our thermostat has "HOLD" on
Hi, Either push the program or resume program button... or on some you need to push the hold button again to take the hold off... Check the manual if all of this does not work... but the t-stat may be fried...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Jul 24, 2011 | Honeywell Electronic Programmable...
Are these thermostats still available
Hi, if you are talking about Honeywell thermostats, yes they are just about any hardware store such as Home Depot, Lowe's, and wholesale a/c and heating houses, but you have to know or be a contractor to buy one there. Home Depot will have them.
Sincerely,
Shastalaker7
Nov 22, 2010 | Honeywell Heating & Cooling
The thermostat worked correctly for months then
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need
May 10, 2010 | Honeywell Programmable Thermostat Heater
Honeywell T8411R 1028No power to the thermostat; breakers are not
site shows this thermostat is a non programmable unit and has been discontinued. none of the info sheets including a pdf shows a replacement battery. this thermostat operates off line voltage only. check for a control fuse or breaker on your heating unit.
Oct 17, 2009 | Honeywell Programmable Thermostat Heater
How do I get my honeywell system up and going?
for now, put switches on thermostat to hear and press the up arrow button to the desired temp. All your programed temps will take more explaining and it would be best you secure a owners instruction book from home depot. oif anything, buy thr same thermostat and either keep it or return it . I'd keep it regardless, read the pmphlet,program you heat and a/c before returning for refund. Don't destroy packaging and give them back everything. You will also need two AAbatteries. Good luck.
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
I have installed a honeywell programable thermostat that has been working well until the outdoor temp reached higher temps. Now it continuously blows like a fan and does not cool the home.
Sounds like the t-stat is wired wrong or if you bought a honeywell from home depot didn't set up correctely. You could also have other issues, like low on freon, dirty filters. You might need to call a Service company to take a look at it.
Apr 25, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
1,499 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
