Question about Homelite Garden
Homelite curved shaft trimmer cs26 sting will not extend by bumbing and it wramps around the shaft and stops the engine. Any ideas.
    President:
  • Homelite Master
  • 1,545 Answers
Check the spring inside and the spool too. If broken, a universal type head can be purchased at Home Depot.
Posted on Sep 06, 2010
Homelite trimlite engine runs but head does not spin
Sounds like the inner flex shaft has broken, slacken the tube up at the engine and pull the tube and shaft assemly away, pull the inner shaft out and inspect
Apr 14, 2012 | Homelite Garden
Is the Ryobi model CS26 considered a professional weed trimmer?
The Ryobi curved shaft trimmer is a consumer grade trimmer. Both the 26cc & the 30cc engines from Ryobi (Homelite) are pretty light duty. They have 1 piston ring and use an anodized aluminum piston and cylinder. A commercial grade engine would have 2 or 3 piston rings and the cylinder and piston would be chrome plated for longer life. Look for the emissions label on your trimmer. The emissions code of C would indicate a 50 hour emissions longevity (consumer grade). A code of B would indicate 125 hour emissions longevity (estate grade). A code of A would indicate 300 hour emissions longevity (commercial grade).
I hope this helps.
Dec 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I remove the cutting head on my homelite HLT=15
http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
Jul 12, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Sparepart for bump feed
Try googling.... www.homelite.com....enter your model number and they will have the illustrated parts page for you to find the correct part you need and it's price...hope this helps.
Jul 04, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Need a manual for Homelite weed eater, UT 20760. It can be in PDF format. Forward to guitar0589@comcast.net. Thanks
You can download the trimmer PDF for free here - http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_trimmer_product_list.html
Jun 28, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Weedeater starts fine but the string head will not spin. I removed the string head, and the shaft it connects to is not spinning either.
The shaft cable has either come loose at the head, or is broken at the engine most likely. Is this a 2 piece unit? If so, see if the cable turns with the grass trimmer section removed. If so, it is usually easiest to just replace the trimmer shaft section. One piece units require disassembly at the engine, and if you are not mechanically inclined, that can be a pain.
Apr 15, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
How do you refill the string on the homelite electric, straigh shaft, 13 in Trimmer?
Is the sting the cutting line at the bottom of the trimmer? If it is pull the spool out. At the bottom of the spool there is an arrow pointing in the direction that the line should be wound. When you first put in the line be sure to place the cutting line in the grove (V shape) and then when you put enough line around the spool. Thread the end of the line thru the hole on the side of the spool. Slide the spool over the shaft of the trimmer and it will click in. When the line is short just tap the spool lightly on the grass and it will feed out more line.
Good Luck.
Jan 06, 2010 | Homelite Garden
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Homelite zip start 2cycle trimmer.
I had this same problem, would run a couple of seconds, stop, and you couldn't start it again.
Had good gas/oil mix 50:1 and 25cc Homelite. Had replaced the fuel filter, gas, spark plug, and took carb apart and cleaned with carb cleaner and primer bulb worked fine. None of that fixed it. What did? Take the muffler off and see if it will start and run with the muffler off. If it does, chances are the muffler is clogged. Also check the exhaust ports and clean them out if plugged with black oil carbon residue.
My muffler was clogged up, took it off, cleaned out the exhaust ports, there was some oil that was in the muffler(oil that didn't burn during combustion). It now starts and runs like a champ on first or second pull.
Mar 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Replace a flexible curved shaft
If you go to www.homelite.comin the red area up top click on order parts then click - click to launch homelite parts catalog, then scroll down thru agreement and click agree and then you will need to know your model number and you can get a breakdown of your trimmer wich will give you a good idea of how your machine is put together.
Dec 16, 2008 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
131 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
