Question about Craftsman 25cc Gas Line Trimmer
I have taken the shaft off of the engine housing. However, I cannot get the silver drum off. It spins easily in both directions.
    President:
  • Craftsman Master
  • 1,545 Answers
Remove the spark plug. Looking in hole to engine, pull on starter rope until the piston is down (flashlight helps). Insert a length of clean soft rope into spark plug hole until it is full.Then....you have just completed the step to stop the engine/crankshaft from turning while you remove the clutch drum. The screw holding it onto the END of the crankshaft is about a Torx (star) #25.It will probably be tight. Turn it counterclockwise to break it loose. It will not come all the way out however and will stay in the end of the neck of the clutch drum. Once that is off...you have to remove the clutch. It is on a threaded section of the shaft.The removal direction is counterclockwise. Use a blut object like a flat blade chisel and whack it sharply near the center on the clutch ears with a hammer. Penetrating oil (Liquid Wrench or PB Blaster) will assist in removal. After that...the worst of the hard stuff is done and you can continue on to what you will.
Please vote on this solution.
Posted on Sep 06, 2010
Testimonial: "Thanks. This was the first explanation I found on the web. The directions were clear and concise."
How do I get into it to change the heating element.
Elements are usually at the back of the drum inside the housing that goes to the fan.
Usually, remove the top, remove the front, from the rear remove the panel that covers the rear drum bearing and unclip the bearing shaft. Remove the drive belt, and then pull the drum forward, up and out. You will see the element either directly behind the drum, or by removing any duct you see at the back.
If you go to YouTube, there is almost certainly a video for your specific dryer.
May 09, 2015 | Dryers
I HAVE A HOTPOINT 7KG AQUARIUSA+ WMF740 AND WHEN IT SPINS IT MAKES A LOAD KNOCKING NOISE AND ITALSO LOOKS LIKE THE SILVER DRUM HAVE FALLEN A BIT
the trunnion (spider) behind the silver drum has corroded and broken away from the drum,you will need to purchase a new drum and trunnion and remove the front of the machine to replace it as well as your at it replace the drum bearings for the trunnion shaft while you have it apart,dont wait too long or the drum can completely break away from the trunnion and breach the cabinet
Jan 07, 2013 | Washing Machines
My Husqvarna 125L trimmer makes a terrible grinding sound and vibration along the shaft. What is this?
Could be a damaged bearing in the gear head, could be a bent drive shaft or outer drive tube, clutch drum may have worn the
engine housing and spinning off centre.
Nov 20, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
Prosedure on how to fix if the uper flex rod goes out it does not spin when motor running
The problem with your upper drive shaft may be clutch related. Here is how to get to the clutch to inspect it and the clutch drum that drives the flexible drive shaft.
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next.It should have some play in it, but not a lot. See if it spins freely. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. If you get the drum off, inspect the clutch. The clutch pads should be uniform with no nicks, cuts or scorch marks. Check the plastic housing on the tube. It should not have score marks either. Next, if needed, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face, Use some lithium based grease to lubricate the upper and lower flexible drive shafts. Post back if needed.
Oct 25, 2010 | Troy Bilt Tb70ss Gas Trimmer
I just bought a BD Grass Hog and after 1 h of use,
If the noise was up by the handle it may have been the drive pulley breaking loose of the shaft on the motor causing the motor to spin and stop the flex shaft of the trimmer. Another possibility would be the small belt that aids the flex shaft. If those don't fix the problem check the lock nut that bolts the flex shaft to the spool housing. If the shaft broke free from the housing the motor would still run and the shaft would turn, but the spool housing would not spin if it does it could be stopped very easily. Definately check the warranty.
Jul 07, 2010 | Black & Decker String Trimmer Cordless 12"...
When machine went into spin it was very noisey and the metal tub has rubbed agaisnt the plastic inside and caused A bit of damage were it rubbed but the rubber seal was not touched I have taken the back...
It sounds like the bearings have collapsed..You may have noticed a noisy spin cycle prior to loosness in the inner drum...This is a big job. Get quotes...Good luck...Nomess
May 20, 2010 | Washing Machines
Can't get the silver spinnning drum off of the shaft
there is another torx t20 screw in center of shaft of the drum. I got the drum off but don't know how to get the clutch off
Aug 11, 2009 | Ryobi Garden
Bosch Washing machine will not spin
Are you able to see the belt? Maybe it broke. If the drum is not spinning than sometime broke that would make the drum spin. If you machine is a direct drive then there is a problem with the drive shaft.
Jun 01, 2009 | Washing Machines
Kenmore elite top loadwasher spins and pumps but will not agitate
Hello, your problem is not the motor, it is the drum shaft collar or what the tub rests on. It is on the top of the shaft. You need to remove the shell, the plastic collar that rests on top of the drum, the agitator, then the nut that holds the drum down, and then pull the drum out, and then you will see the collar. I know it is hard to get to so I would call a pro for this job unless you think you can do it. The part is cheep it is the labor that will cost you. Thank you
Dec 01, 2008 | Kenmore 24032\24036 Top Load Washer
Oil leakage
its a reversed screw
not the righty tighty lefty loosey
its righty loosey lefty tighty
its because of the drum spinning the drum cant come off in this bolt direction
Jun 02, 2008 | GE WBB4500EWW Top Load Washer
Craftsman 25cc Gas Line Trimmer Logo
183 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
