Back to:
Tags:
Casio EXILIM  Card EX-S770 Digital Camera
Battery Charge error
posted by Lak_69 on May 13, 2008
I purchased a Casio EX-Z40 a few years ago and recently the camera keeps on shutting down by itself when switched on.
When I try to switch it back on again, sometimes it works and sometimes it doesn’t.
I showed it to somebody and he said that battery is overcharging to around 4.2v when it should be 3.7v and he said I should buy new battery.
I have now purchased a new NP-40 Lithium ION battery (3.7v 1230mAh) and tried to charge it using the USB cradle supplied with the camera.
However when charging the new battery the ‘charging’ light keeps on flashing on & off when it should be constantly red.
I then tried the old battery and the same thing happens ie charging light flashing on & off.
The manual says it’s a ‘charge error’………………so is there a problem with the USB cradle or camera itself?
Any help will be greatly appreciated.
Comment by Lak_69, posted on May 14, 2008
Thanks Allan for the response. When I purchased the camera a few years ago it came with a Casio Exilm NP-40 battery and has been working brilliantly without problems, until recently. So I am confused as to why I now need to change to a NP-20 battery?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 13, 2008
Inappropriate (40)
Agent Allan
Rank:Guru Guru
Rating: 86%, 241 votes
Hey Lak_69,
One problem I know of is the battery for your camera should be model NP-20 not model NP-40. The NP-20 has 650mAh. I would exchange your new battery for the correct model battery, and see if this works. If this doesn't work I would try cleaning the battery terminals in the camera, and if that doesn't work go ahead and try a new charger.
Sincerely,
Allan
Go Ahead. Use Us.
Rating Locked! (?) Lak_69 has rated this solution as Inappropriate
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Battery Charge error:
I don't want to Accept this solution
Can you Help with these Digital Cameras problems?
problem 1:i can't open the pictures in my computer. the...
i have had my 5 mega pixels camera since christmas and it...
Dear Jackboy : In the post...
1.5 year old EX-S770 has been used but not...
Hi I have had the camera for about 1½ yaers now....
Loading problems.
Repair Service
Find Digital Camera Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
