Question about Oreck XL M900A Upright WetDry Vacuum
We have a M800 series Rinse-A-Matic we cannot get the shampoo or the rinse water too spray any ideas ? We have done everything in the owners manual it does **** and when you turn the pump it you heaR IT.
  • 29 Answers
SOURCE: not wanting to spray shampoo/water piece of ****!!!!!!!
Capt. Obvious fixes: Of course make sure there's clean water in the bladder of the water tank and soap in the soap tank, and make sure the dial is set to Floor Cleaning, not Tool Cleaning or somewhere in between.
Sometimes an air pocket inside the machine (even a new one) keeps water from flowing, until you reprime the Bissell's internal pumps. To prime the pumps the easy way, turn it on, then press, hold, and release the water-and-soap trigger a few times, waiting a few seconds each time.
Still nothing? Prime it the slightly harder way. Separate the two water tank pieces. Only have the base tank filled and mounted on the Bissell without the piece that sits atop the tank. Turn it on. Kneeling on the floor in front of the Bissell, reach up and press the soap and water trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel just a bit of suction. Lift your hand up and down a few times, a few seconds apart. Release the trigger and repeat a few times.
Still no liquids? If your Bissell has been used at least a few times, particularly if you didn't thoroughly clean the machine when finished, but after a year or so in a hard-water area like mine even if you are good about cleaning it, the water sprayers on your Bissell may have clogged with mineral deposits. This is a *fairly* easy thing to fix yourself, but please read all the way to the end and check out the GOTCHA before trying this.
Unplug the Bissell. Remove the water tank pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your roller brushes when you press the water-and-soap trigger at the top of the Bissell's handle, and tend to clog with mineral deposits.
Only work on one sprayer at a time so you can see how it goes back together.
As you squeeze the red plastic sides of one red water sprayer, push up on the underside of the sprayer from underneath the bottom unit of the Bissell to release the sprayer from its mount in the base. Clean any lint or debris out of the mount area. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove one water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip up the hose so it compresses the spring and is no longer on the red plastic water sprayer. (See GOTCHA about the spring, below.)
With the clip released, now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the end of the red water sprayer that was inside the hose in your mouth and seal your lips around it, and try blowing through it. If you can't blow air through it, it's clogged. Open up a paper clip and push it back-and-forth through the small hole in the hose end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Click the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
The GOTCHA: Once when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. It’s best to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, fix this by removing the six screws on top of the Bissell base (this is the surface the water tank mounts on top of), and pry it up. Pull out the hose, reattach the red water sprayers on the hose, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
You might want to prime the pumps again (instructions above). If the sprayers are clear, and the pumps are primed, but it still doesn't get the floor wet when it should, the problem may be more serious. You may need a pump or motor inside the unit replaced.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Thoroughly rinse out and empty both water tank pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and get all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and needs more pampering than a vacuum cleaner, doesn't it??
Posted on Jun 08, 2009
sparktgo
  • 68 Answers
SOURCE: need manual for steemer
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/XLS465.pdf
Posted on Oct 12, 2009
glasgowlove
  • 40 Answers
SOURCE: Sucks but does not spray water.
have you checked the nosel were the water come out for blockages ?. try dismatal it and clean though with water cold.
more advice contact your manaual
Posted on Oct 30, 2009
  • 10 Answers
SOURCE: I need a manual for Oreck Rinse-A-Matic (how to
Go to Oreck.com. You can find the user manuals for all of their products there.
Posted on Jan 02, 2012
SOURCE: My oreck rinse-o-matic vac keep
I had the same problem...kept pushing the reset button on the plug, but continued to shut off. Took it to my local electrician, who removed the plug w/reset and replaced it with a regular plug...works fine now. Must've been a short in the reset part...sometimes simpler is better! Cost me $7.00, lots cheaper than a new machine or the $100 repaire quote from oreck!
Posted on Feb 15, 2012
Don't know how to use with shampoo
Best to not put shampoo in machine. Put traffic lane cleaner in sprayer with hot water, spray onto carpet after thorough vacuuming, allow cleaner to dwell 5 to 10 minutes and clean and rinse with fresh clean water in machine. For best results do NOT put shampoo in he machine even though it was designed for it. Most of the machines brought in for repairs are clogged with soap gunk. Carpets will be cleaner and stay clean longer because the soap has been rinsed out of carpet
Sep 26, 2013 | Vacuums
F7210-900 Steam Vac. will not put out water when switch is in wash position but it will put out water when the rinse position
There are two electrical solenoids inside the hood assembly. One opens to dispense rinse water, and the other dispenses the soap and water solution. It is likely that the soap and water solenoid has failed and will require replacement. A "work around" fix for this is to mix the soap solution in the clear water tank ( 5 oz. of shampoo per gallon of water ), and shampoo that way until the solenoid can be replaced.
Mar 15, 2011 | Hoover Vacuums
Proheat2x
when you are wanting to use rinse only???
Dec 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Rollers don't turn and pump doesn't put out any shampoo or rinse water
You need to replace the Pump belt and the roller brush belt. You can get both belts and view the manual which has instructions here:
Bissell Proheat Replacement Belts and Manual
Nov 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Need manual for steemer manf by Oreck Rinse a matic
Oct 12, 2009 | Oreck XLS465A Upright Vacuum
Constantly sprays water
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=515776&thid=544922
Posted by elstretcho on Apr 25, 2008
Hoover F7452-900 SteamVac Upright Vacuum
I noticed recently that our Hoover F7452 All Terrain constantly sprays water. As soon as I turn it on, whether or not it's set to Rinse or Auto-Rinse, its leaking water at the brushes. I probably wouldn't have noticed but I attached the hand-held adapter to clean our stairs and when I was done there was a HUGE pile of water under the vac. I took everything off and cleaned really good and looked again this morning and its still doing it. Any ideas?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You probably have a bad trigger release valve or a loose connection @ the bottom of the SteamVac or the gasket under the solution tank in not sitting on there right and is leaking or you may have a small cut in the hose, but it so may guess that it is a bad trigger release valve or a bad gasket. Check with your local vac dealer to see if they have a new or a good used one to see if there is the problem or back track the problem from the bottom to the solution tank. So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Hoover F7452-900 SteamVac Upright Vacuum
Hoover Steam Vac with Rinse
The bottom tank is for the dirty water, the top tank, it has a small tank attached to it for the shampoo, clear hot water goes in the bigger tank. Then turn it on, squeeze the trigger as you pull it backwards. It will spray and vacuum up at about the same time.
Mar 05, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Oreck XL M900A Upright WetDry Vacuum Logo
349 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
