Question about Clarion CZ209 Car CD/ MP3 Player
In my beachcomber Hot tub the Clarion CD/MP3 Player.Was working fine but know on the display it says AMP GRD and there is know sound.
5 Suggested Answers
SOURCE: Clarion DB245 CD player
I think you press and hold the band button then press the display button
Posted on Jan 20, 2008
etirbynnor
  • 655 Answers
SOURCE: clarion cz 209 problem
Hello sashunter,
The most likely cause for the problem is that either the power antenna lead or the amp remote turn-on lead has shorted to ground somewhere behind the dash.
Pull the unit back out and make sure that the ends of all of the unused leads are completely covered.
The best way is to use an insulated crimp-on closed-end connector on the end or each unused wire. Heat shrink tubing is also OK. Fold the end of the wire back into a "U" shape and shrink the tubing over the "U" overlapping it about 1/4" on both ends. You can use electricians tape as a last resort, but it's messy if you ever need to remove it and sometimes it just comes off by itself.
Hope this helps.
Posted on May 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: my clarion cd player in my boat was working fine
Remove all the speaker wires.
Power the radio back on and verify it is not the radio at fault.
If it powers up, check the speakers with a Digital Multimeter set to OHMS 20x.
Each speaker should have a resistance of 4 ohms. (or 8 in some cases)
Any variance (+/- .5ohms) means the voicecoil is blown, and replace that speaker.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 19, 2009
  • 222 Answers
SOURCE: The Clarion radio in my vehicle has the word AMP
Is this a newly insalled one? check your wiring's, you may be lacking ground connection.
Posted on Jun 08, 2010
BEACHCOMBER HOT TUB NO DISPLAY
This could be failure of the display, the controller, or both.
Dec 12, 2013 | Jacuzzi Pool & Spa
When i turn stereo on and there is no sound and AMP GRD comes up. how do i sort this out
The amp needs a ground green wire. Attach it to a metal object with a screw. The wiring harness will have a green wire sometimes with a factory installed ring on it to be able to attach it to a ground
Apr 07, 2013 | Clarion CZ109 Car CD Player
AMP GUARD
Amp guard is a protection circuit built o protect the output from short circuits. Please check your speaker wiring for shorting. Once cleared your system should work fine.
Jun 06, 2012 | Clarion DUZ385SAT Car CD/ MP3 Player
Why does my radio say amp grd when there is no amp hooked up and it was playing just fine tell now
sounds like you need to check your speakers and/speaker wires to make sure you don't have a short to ground or bad speaker. if those check out, you may have a bad output ic inside of the deck.
May 30, 2010 | Clarion DXZ438R CD Player
My clarion cd player in my boat was working fine now it says amp grd. I have looked but i see nothing unhooked what can i do to get sound out of my speakers?
Jul 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
My clarion dxz385usb has no sound.
Check to make sure exposed wires aren't grounding themselves out. I just had this problem and after 2 days of re-wiring and re-checking almost every wire I finally found the culprit. The Remote wire from my amp has become exposed and grounded itself out. Unit worked fine, same problems you are having.
Jun 13, 2009 | Clarion DXZ475MP CD Player
Installed and no sound or nothing
Im guessing you have an amplifier if not check the cd player ground " AMP GRD" means amp ground is faulty. In the event that you do have an amplifier check that ground wire as it's most likely the problem.
Feb 25, 2009 | Clarion DB285USB Car CD/ MP3 Player
Clarion CZ209 Car CD/ MP3 Player Logo
125 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
