Question about IBM ThinkPad T30 2366 Notebook
Dont hear the fan running... WHAT ISSUES CAN THIS CAUSE AND WHAT SHOULD i DO?
    Guru:
  • 689 Answers
Often a delay when fan starts --it's not important unless the C.P.U.is overheating.if the fan just isn't running--replace it --there quite cheap and easy to service.
It might just be clogged up with dust --you can get a small can of compressed air with a fine tube on the nozzle to clean it out--sorta even jump start it again with a light push of a pencil end --unless it really has failed--its only the bearing in the centre that fails usually
Posted on Sep 06, 2010
High pitched sound coming from refrigerator sounds like loud whiny humm
TRY AND LISTEN TO UR COMPRESSOR SEE IF U HEAR ANNYTHING THERE? IF NOT CHECK UR COMPRESSOR CONDENSOR FAN AND FREEZER EVAPORATOR FAN FOR BLOCKAGE OR OBSTRUCTIONS? OR POSSIBLY 1 OF THE FANS MOTOR IS GOING OUT MAKING FUNNY SOUNDS, ANOTHER THING COULD BE A BAD DOOR SEAL ISSUES WHICH OVERWORKS THE COMPRESSOR AND CAN CAUSE IT TO MAKE FUNNY NOISES
Oct 02, 2014 | Hotpoint Refrigerators
The cooling fan is on
Usually the fan stays on because your PC is overheating! First try and see your PC has at least 5 cm (2 in) space all round.
2. Dust
You computer fan may have accumulated a lot of dust, which causes the fan to run continuously. Purchase compressed air spray and spray the computer fan to loosen up any dust that may have accumulated. Most computer fans are exposed, so accessing the fan should not be a challenge. Brush the blades with a soft artists brush if the dirt is still on, but GENTLY
3. Technical issues
In some cases, your computer may have either a defective fan or thermostat. Some Computer providers allow you to purchase a new fan and replace it yourself. For thermostat issues, you may have to contact a computer repair professional for assistance.
4. Computer is overworked
Depending on the age of your computer multiple programs that are running can cause it to overheat. Watching a lot of DVDs, playing video games, and listening to music on your computer also can cause overheating. Considering closing some of your programs and rebooting your computer.
May 03, 2014 | Acer Aspire 5600U all-in-one desktop
Bmw 318 compact 2002 wont start
How low is the alternator? 13.5 v with the motor running is about as low as I would want, but if you hear something running after you turn it off, it could be draining your battery. It is not uncommon for cooling fans to run after you turn the car off but shouldn't run for long. Can you look at yout cooling fans and see if that is what is running? How long do you hear the noise after you turn the car off?
Jan 14, 2014 | Cars & Trucks
Mother has no beep
If u dont hear a BEEP with is a code for Hardware issues most often is PROCESSOR failure or whole MB issues. I would first try to see if POWERSUPPY is getting fried. I would chk for burnt smell or now fan activity. then see if the processor fan spins. Does the bios screen comes up or drives spin or any thing light up? also sounds stupid but cables and connections sometime do CHIPCREAP..work loose but if your not expierenced at inside play then if OEM call techsupport or local computer store can do cheap dianogstics..goodluck
chadman
Dec 09, 2013 | Intel D865GVHZ Motherboard
Can you replace a fan in the samsung DLPTV model #hln437wx/xaa
it has 2 or 3 fans---they rarely fail but can cause issues---Are you hearing a high pitched whine or fan like sound? I KNOW WHAT THAT IS IN THIS SET...
Apr 09, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
Hi. so ive got this old Toshiba Satellite PSL30L-00100E and im not sure whats wrong with it. when i open properties on "This computer" it wont open untill it have gone a fair bit of time. and...
Hello, it seems you have more than one issue at hand but lets start with the blue screen, this is typically caused by driver errors on your system. You should check the manufacturers website for the latest drivers available for your system. The CPU is a bunch of different issues so it's hard to zone in on one. Most likely cause lack of RAM, best possible solution try not running too many programs simultaneously. If you are willing to spend on this computer there a lot of programs available online to aid in improving the overall performance of the system one such is Ashampoo win optimizer.
May 10, 2011 | Intel Celeron M 380, 1.6 GHz Celeron M...
I have a 2003 Mitsubishi Lancer. A few weeks ago when I turned on the air I could hear like a rattling in the fan. Now the air will run for a little while then slowly weeken until it just stops. What could...
This could be a number of issues but most commonly it need charged. "low frezon" When low it will cause it to run slow or not at all, good luck on it.
Apr 19, 2011 | 2003 Mitsubishi Lancer
My HP laptop keeps shutting down after a while. What can cause this?
It may be overheating. Can you hear or feel the fan working?
Look for the air vent at the back or side of the laptop, and ensure that you can hear the fan running and feel an aiflow. If the fan is not operating then this is almost certainly the cause.
If the fan is not operating the cause could be on of several things, but most likely you will need to replace the fan.
Post here again if you want further advice.
Mar 29, 2010 | HP Pavilion dv2000t Notebook
Top frig not cooling but bottom freezer is
The fan in the back of the freezer is for the freezer as well as the refrigerator. If the fan runs to slow the refrigerator does not get the chilled air, which cause it not to cool. I would have the fan swapped out to solve problem
Jul 25, 2009 | Kenmore 73503 Stainless Steel Bottom...
Crazy fan nosie
Noise from computer You should only expect to hear a slight hum from the CPU fan; below are some issues that may cause additional noise from your CPU fan.
Click on the above link , follow instruction, Good Luck.........Please dont for get to Vote.Thank You.
Dec 15, 2007 | E-Machines M2352 Notebook
IBM ThinkPad T30 2366 Notebook Logo
35 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
