Question about Kenmore Washing Machines
I have a Kenmore HE2 Dryer Type: DHZN-NAT-1206006-ELZ0 Model #: 110.97511701 that is not heating up when a load of laundry is in to dry. It will spin & eventually dry, but there is no heat. What do I need to do?
miket756
  • 2702 Answers
SOURCE: Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Posted on Oct 24, 2009
vickygomar
  • 460 Answers
SOURCE: Kenmore HE2 Dryer Does Not Autmatically Shut Off
We need the error code # please
Posted on May 12, 2009
  • 35 Answers
SOURCE: my dryer appears to work as normal, but not
You should unplug the machine and check the igniter to see if it shows any signs of damage. If it is damaged, replacing it should solve the problem. If it does not show damage there are a number of things it could be and it may save you money in the long run to call a techncian for service.
Posted on Dec 01, 2009
  • 290 Answers
SOURCE: my washer spins but do not dry
Assuming you have slected the right options on your control panel, sounds like your heaters are faulty, or the safety cutout is open due to a fault, in either case you need to take it apart to have it looked at.
Posted on Jan 03, 2010
  • 39 Answers
SOURCE: I have a kenmore HE2 dryer and matching washer.
Make sure you check your exhaust line and where the air blows to the outside. If your exhaust vent or hose is bent or restricted it will take a very long time to dry the clothes. Sometimes the vent flap on the outside exhaust is stuck shut. Clear dryer exhaust venting is critical for proper operation. Several companies offer a vent cleaning service where they completely clean out the exhaust lines.
Posted on Feb 03, 2010
My kenmore dryer with serial number: DESR-NAT-1206006-FM22 doesn't have heat at all and my clothes are still wet. What to do before I call the repair guy?
Clean lint screen could be clogged a dryer sheet can sometime block the grille if a loads to large and heavy that will result in wet clothes.some dryers have an option for air dry if that is selec
Jul 24, 2015 | Kenmore Dryers
Kenmore 700 series dryer problems
This could be a few things. The first thing to check is your dryers vent, make sure its not clogged and check were it exits the house because sometimes nest are made in them. A clogged vent will prevent proper drying because the moisture can not escape and/or the heating element turns off due to overheating.
If the vent is clear, with dryer empty open the door and hold down the door switch (button that tells dryer door is closed) and turn on dryer, as its running watch the back area of drum were the vent with little holes is, within a few seconds you should start to see an orange glow in that area. If the orange glow starts then disappears within a few seconds it means your vent is clogged, if there is no orange glow at all then you have either a bad heating coil or bad high limit switches. I believe youtube has great how to videos on how to replace them, its not that hard if you have basic repair skills. Hope this helps you and your able to get it drying agian
Dec 23, 2013 | Dryers
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
Type:DWSR-NAT-1206006-CV22. The Kenmore gas dryer runs and spins but does not heat up -the clothes remain wet. Lint is not the issue . Iclean the lint trap every load. I also vacuumed out the coil vent ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 03, 2011 | Dryers
I have a type DHZN-ELE-2406024-EL54 model
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer won't dry
There are three possible parts that can cause this.
1. Thermal fuse
2. Thermostat
3. Flame sensor
https://www.repairclinic.com/Shop-For-Parts/a8b6d600503/Model-11072212100-Kenmore-Dryer-Parts
You can check the first two with a meter to see if they are ok. If they are then you should replace the flame sensor.
Mar 25, 2017 | Dryers
Washing Machines Logo
99 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
