Question about KitchenAid KSRS25FG
My Kitchen Aid will refrigerator motor keeps running. Things are cold but the motor sense like it is always running.
  • 50 Answers
If it is not freezing up or set too cold, you may be losing coldness somewhere. Are the seals all in good order? Do you open it very often and leave the door open? Do you put hot stuff in the fridge? All these things would contribute to that problem.
Posted on Sep 06, 2010
Refrigerator motherboard How can I tell if the motherboard of my kitchen Aid refrigerator went bad
Make sure your fridge doesn't have a recall for evaporator as is the case on my fridge I also thought it was electronic and first tech thought it was a leak in reality the evaporator was clogging and causing freon to not keep fridge cold or freezer to work properly but kitchen aid won't let you know you will have to let a tech look that info up for you.
Mar 15, 2014 | KitchenAid Refrigerators
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
Our Kitchen Aid Refrigerator Is not getting cold enough to keep our food cold,What could be the problem and how can I fix ie myself?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 25, 2011 | KitchenAid Refrigerators
I have a Kitchen Aid Superba refrigerator and it quit keeping things cold/frozen. I cleaned the coils but the compressor doesn't come on, just the fan. Is there a reset button for the compressor? Model...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 22, 2011 | KitchenAid Refrigerators
I have a Kitchen Aid Md# KBLA20ERSS The
Lack of airflow up to the refrigerator. could be a defrost problem, a fan motor not running, a damper staying closed, a food obstruction, or something else altogether.
May 09, 2010 | KitchenAid (KBLA22ER) Bottom Freezer...
MY KITCHEN AID SIDE BY SIDE FRIDGE IS NOT COOLING. tHE COMPRESSOR IS HOT AND APPEARS TO BE RUNNING. Please help. Frank
1.The fan motor at the compressor must be running to keep the compressor cool.2. If you hear a clicking sound at the compressor,that is a indication of a bad compressor start relay that must be replaced.
Nov 11, 2009 | KitchenAid (KSRD22FKST) Side by Side...
KSRG25FKWH04 is not getting cold its a kitchen aid side by side
See if you can hear the evaporator fan motor running in the freezer, if not, you need to replace it because it forces the cold air from the freezer into the fridge section to keep it cold.
Nov 11, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a Kitchen Aid refridgerator. My freezer
Hi, Check the rear inside panel of the freezer section and see if there is a frost build up. Also check and make sure the evaporator fan motor in the freezer is running.
If there is a frost build up, remove the rear indise panel and check the defrost heater and bi-metal switch for continuity. The bi-metal switch located on the top of the evaporator has to be tested while it is still cold.
If either of them show an open circuit, it will need replaced. If both of these parts show ok, you will need to replace the defrost timer/board.
Please let me know what you find and if I can assist you further.
Vic
Jun 28, 2009 | Jenn-Air JCB2280HES Side by Side...
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
216 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
