Wash enhanced, reduced creases and on/off lights are all flashing on our hotpoint aquarius wt540, then it stops working and wont drain the water and spin.
This has happend to my washing machine could u please tell me how to unblock the pump
Posted on Oct 06, 2011
My washing machine has done the same and my pump was blocked. hope this helps.
Posted on Nov 28, 2010
My washing machine is not working
Sounds like a communication error. remove lid and unplug top consol panel for 5 mins ,make sure connections on bottom pcb are tight ,if that dont work replace your PCB
Mar 08, 2015 | Hotpoint Aquarius WT540 Front
Hotpoint wt540, reduced creases and extra rinse lights are staying on all the time
1) clean the contacts ribbon with erase pencil and put a little ethylic alcohol.
2) try it 3) if the problem persist the control board is faulty.
God bless you
Oct 11, 2012 | Hotpoint Aquarius WT540 Front
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Lights flashing on WF320P
i'm having same problem people have said empty filtter but i have done that and the water is running out but still flashing
so sorry wish i could help.
Sep 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wt540 wont pump out water
Hiya Barry, I have the same machine and for the last 3 days have had the exact same problem...mini load and reduced crease as well as power light flash right when it comes to drain...?
I have scratched my head and done lots and lots of research, reckon I could design and build my own washer now lol, anyway, I fitted a new pump and ran it, thinking this is it sorted, went out and got a call from our lass...doing it again.
Right, gonna have to get me hands dirty...I removed the drain hose (Ignore the pump for a second, I'm talking about the grey hose that goes from the pump to the sink) from the sink and poked my fingers as far as they would go...debris, I then removed it from the other end (Pump) so I had a long hose in my hands, not attached to anything at either end....cleared it and again, loads of debris (Fluff, plastic etc) and put it all back together...turned the old fella back on and running a wash right now as we speak...happily spinning round at 1400rpm and throwing gallons of water down the sink...I would consider it fixed.
So I can most definately tell you that you have a blockage somewhere mate, I'd get your hands in the toolbox and pull that pipe off, doesn't require any level of experience, just the ability to put things back as you found them...
Hope that helps
Nov 23, 2008 | Hotpoint Aquarius WD63 Front Load...
We have a hotpoint wd420 washing machine and it wont finnish a wash cycle. wont drain the water either, we do get an error code though in that the door locked light flashes as well as the reduce creases...
you have a blocked pipe - where the water is draining out. Either that or your filter is blocked.
best you open the back and take a look at the filter before calling out hotpoint - might save you 100 pound call out charge.
Jul 28, 2008 | Washing Machines
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Sounds like the water pump is plugged with something. The pump could also just be locked up. The smell is probably the belt slipping on the pulley. To drain the unit you will need to lower the drain hose into a bucket and let it drain that way. Most pumps can be opened and cleaned. It will be inside and attached to the drain hose. It has a pulley on it where the belt rides. If it has a clamp holding the bottom on remove it and the clog. You may be able to do this without removing it from the unit. Let me know if you need further help.
Feb 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
601 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
