Question about Sony DAV-FC7 System
Sony AV System DAV-FC7 cannot turn on
Cannot turn on system. Have the red light on the on/off switch but cannot turn on by pushing or using the remote
  • meebo791 Mar 20, 2009
    I had the same problem a week ago and had unplugged and plugged back it to make it work. I had powered off each night for a week and have the problem again. This solution isn't working at the moment.
Now the solution (rather, a workaround) for this problem is power off the main supply (or remove the plug from the electrical outlet) and then plug it again. From now, on do not power off the unit. If you have to, then you need to perform the work around again.
-Sathish
Posted on Jul 24, 2008
  • beanpole1120 Jan 20, 2011
    I am having the same problem. What was the final outcome of your sony dav fc7? How long did it last and if you had to get it fixed, how much was it. Thanks
I'm finding that the solution to this is not working at all. I have had the darn thing unplugged for a month, I was plugging it in, unplugging it...is there not a reset for the unit?
Posted on Jun 24, 2009
I have a bose tv speaker system. I have not used it in awhile. I cannot seam to get it working. the red light is on the remote device that sets under the tv.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Dec 14, 2016 | Bose Televison & Video
Sony DAV-FC7
the last sent DVD was bad i think
May 13, 2008 | Sony DAV-FC7 System
Led light is always on even when im driving and the remote start does not work....what do i gotta do....thanks
The LED light always on means the system is in valet. The remote starter should still work in valet so, check your hood pin switch to make sure the pin is making contact with the hood when the hood is closed.
Locate the valet swich under the dash. It's a black push button. Turn the ignition on, press and hold the button, count to five. Release the button, the light should go off. If there is a remote starter shut down installed, it should be located near the valet switch. It's a toggle switch that may still have a red boot over it. Flip the switch in the opposite setting. The remote starter should work afterwards.
Jun 28, 2011 | Car APS997A Two-Way Remote Start and...
Can i watch regular tv and use the dav-fc7 as audio?
just run the "line audio" not your speaker audio out from your tv to the aux or dv/cd input...
on your dav-fc7 it will sound great! just turn the tv audio sound down at the set.
Dec 03, 2010 | Sony DAV-FC7 System
Track lighting remote control similar to that of ceiling fan?
Yes, but the remote operates on the switch that turns the lights on and off. Lutron has this kind of technology and it is really cool. I have it all over my house and I don't even have to go room by room turning lights off; I just push a button from my bedroom. Along with a single remote that can be used with each switch in your house, you can program a house remote that controls the lights and ambiance of every room.
Jun 03, 2010 | Universal Remote Control Hampton Bay...
Remote control wall unit does not turn on Monte Carlo fan or light although red light comes on when buttons are pushed (fan and light worked for about 2 years although it was hardly ever used).Frank
Are the manual switches on the fan in the 'on' position?
Select the maximum fan speed on the remote and then operate the manual switch on the fan. Set that to the highest speed then control it with the remote.
Same theory applies to the light.
If this is not the problem then the remote receiver on the fan is probably faulty.
Feb 28, 2010 | Monte Carlo (5LCR52MW) Fan
Will not turn on
There is a mod that has to be done to prevent this problem which the average person can not due as you have to put a resistor from one spot to the another spot to a pin on the microprocessor. A shop that repairs Sony product will be aware of this mod.Usally takes about a half of an hour and a 10 cent part is required. repair will run around $100.00 if taken to a shop.
Jan 04, 2010 | Sony DAV-FC7 System
Astra remote car starter problem
your remote starter is in valet mode, the door lock will still work but no remote start, try pressing the trunk button 3 times, if that doesn't work turn the ignition switch on and off 5 times
Jan 03, 2010 | Astra Car Alarm And Remote Starter,...
I am attempting to adjust my wii remote sensitivity. The minus button will not work. it is currently set at 5...when I press the plus button it beeps as if I am adjusting in the positive, however when I...
Here are few Home remedies that should help you fix the issue.If you still face any problems then it is an internal issue with your remote and you will have to contact the nintendo support.
  1. Clean the Wii remote pointer lens. Use a soft cloth to remove any sticky substances. Wii remote jackets, stickers or other objects should not block the remote pointer lens, as it will cause characters to move erratically, disappear or remain off-center.
  2. Operate the Wii remote between three to eight feet away from the sensor. Otherwise, it will not perform properly.
  3. Note that infra-red lights from candles, toys, appliances, fireplaces and even sunlight may effect how the Wii remote performs. Try to remove or reduce infra-red interference from these sources when possible.
  4. Turn off or move wireless devices located near the Wii console. You may be experiencing radio frequency interference from other wireless devices.
  5. Check to see if anything is blocking the sensor. Clear objects away from the sensor and console to enable the remote to send a clear signal to the Wii system.
  6. Center the sensor bar directly below or above your television. Having the sensor off-center may cause the Wii remote to perform poorly.
Re-sync the Wii remote to the Wii system:
  1. Completely turn off the Wii system. Remove the batteries from the remote. Turn the power off on the Wii console. Unplug the unit from the wall. Wait five seconds and then replug the unit into the wall.
  2. Push the power button to turn on the Wii console. After the health and safety screen appears, open the small door on the front of the Wii console. Locate the red SYNC button. Push down on the SYNC button for fifteen seconds. This resets all previous SYNCS on the Wii system.
  3. Re-sync the Wii remote. Locate the red button on the remote control under the battery cover. Push and release this red button. The Wii remote should respond with blinking blue lights.
  4. Push and release the red SYNC button on the Wii console. Place the batteries back in the remote. When the remote is successfully re-synced, the LED light will remain lit.
  5. Repeat the re-syncing process with all other Wii remotes on this system.
Thank You
Oct 19, 2009 | Nintendo Wii Console
Sony DAV-FC7 System Logo
749 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
