Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
I want to remove the deck for blade sharpening
  • 5 Answers
Just remove the blades.
Posted on Sep 12, 2010
Ihave a craftsman ridding mower model #917.289900 new belt for the deck new blads it still leaves miss cut in the middle anybody know why?
usually if its missing cut it's not rotating fast enough, or the other thing it can be the blades have not been sharpened. some companies that make blades don't sharpen them so they can be handled, it will have a leading edge and you need a sharpening stone to put a cutting edge on the blade. and the blade has to be put in the right way round. flate top cutting edge bottom.
Jun 14, 2017 | Craftsman Garden
Mower leaves strip of grass unmowed in center of deck. This is a model X300 with newly sharpened blades
Check the center blade to make sure it spins freely when the deck belt has been removed. The spindle may have frozen up.
May 26, 2016 | John Deere Garden
How do you change cutting blade on a Sears Craftsman Mower?
Hi Bill:
Changing blades is pretty straightforward but does involve some Safety Hazards.
- Blades can have sharp bits - WEAR GLOVES
- Running engines can make the blade BITE - BAD
ALWAYS disconnect spark plug lead whaen changing blade.
Easy Part:
- Raise deck to maximum height
- If possible, park with front wheels on a ramp to get better access under deck.
- Use socket wrench to remove bolt from centre of blade. Here's where the gloves help as you hold the end of the blade to prevent it from turning when you apply force to remove the bolt.
TA DA! The blade will come off.
- To install new or sharpened blade (I use an angle grinder to sharpen mine) tuck it in place, install the bolt, snug it up, make sure any notches or splines line up, protect your hands (gloves) while you tighten the bolt. and you're back to cutting grass.
Cheerfuls.
Oct 19, 2015 | Craftsman Garden
How do I change blades on a toro 42 in zero turn
Lift front of machine and secure,
Use a pipe wrench over top of blade and against deck, to keep blade from turning,
Use 1/2 " breaker bar to loosen bottom bolt,
Remove blade,
If the bottom bolt doesn't loosen, you may need a wrench at top of deck, above the bottom bolt, to loosen the bottom bolt.
Replace, or sharpen blades, install in reverse order.
GOOD LUCK FRIEND.
Sep 16, 2014 | Toro 42 In 22 Hp Kawasaki Vtwin...
Toro 50" time cutter when engaging blade loud
I would remove the deck and belt, then spin each blade to isolate the loud noise. Also, make sure the blades are not bent hitting the deck. I always balance my blades after sharpening as well. By isolating the bearings spinning them one at a time, this will tell you where your problem lies. Hope this helps!
Aug 10, 2013 | Garden
How do i replace a blade that had fallen off. 42 inch tractor. The main problem is how to get underneath the tractor?
To replace blades, belts, sharpen blades, etc. one must remove what is called the cutting deck from the tractor.
Once the deck is off the tractor, pull it out, turn it over and you can work on the blades.
Gary
Jul 10, 2011 | Ariens 42" Riding Lawn Mower Blade ...
How to remove deck on 1045 cub cadet to remove and sharpen blades
You should be able to remove the blades without removing the deck
They bolt on from underneath with either a single or double bolt set up
90% + are single bolt
Mar 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
How to drop mower cradle to sharpen blades or is there a better way regardes dennis
raise the deck and drive up on ramps. remove blade retainer bolt then blade. be sure to notice which side of blade is down.
Nov 27, 2009 | Garden
Blade on John Deere L110 will not shut off
Check the cable that runs from the acuating lever to the tensioner pulley on your deck it could be broken or frayed. also check the plastic holder on the deck end of the pulley, it fits in a small groove in a brace on the deck and is held in place by a tractor pin. when they removed your deck to sharpen the blades they may not have re-connected it properly or the plastic holder may be broken and not allowing the proper tension on the cable. if your tractor is equipped with a PTO switch near the lever check the connections and the continuity of the switch...hope this helps.... ;-D
Aug 10, 2009 | John Deere Garden
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
67 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
