Question about Epson Stylus C84 InkJet Printer
Ink printing problem
Hi there! I have a epson stylus c84 photo edition printer, it prints but no ink comes out ive tried new cartridges and nozzle clean about ten times and head clean but still no luck, would changing from windows xp to vista have anything to do with it?? please help!!
  • 103 Answers
Did you remove the plastic from the bottom ofthe cartridge, if not do so and changing from vista to xp would change that probelm.
Posted on May 13, 2008
  • Jamiell Joseph May 13, 2008
    sorry. changing from vista to xp would not change the problem
Hi there, I have an epson d120 that will print but the print is very faded. Can you help? I have put in new inks but still having the problem.
Check nozzle, do head cleaning procedure. Wait for 30 minutes. Check nozzle again. If there are no difference betwen to output of nozzle check, you have to cleaning head manually. Check for it at aicaxz solutiuon.
Oct 18, 2009 | Epson Stylus D120 Network Edition ultra...
My epson stylus c84 prints, but there's no ink on the paper
This might sound stupid, but did you remove the plastic film that covers the head?
Try this, if still nothing happens, go through your printer settings and run a "Cleaning" cycle on it.
Aug 28, 2009 | Epson Stylus C84 InkJet Printer
My epson stylus c84 printer does not print
Thanks for using FixYa. The printer won't operate properly if it's tilted. Place it on a stable and flat surface. Please do not leave your printer turned on when not in use to avoid print heads being clogged. In the instant case the ink cartridges can also leak into the printer. If the print heads are clogged then run the head cleaning and alignment utility. The print head nozzles may also need cleaning.
Please do rate the solution and revert for further assistance.
Aug 24, 2009 | Epson Stylus C84 InkJet Printer
Epson c84 printer not printing after installing new ink cartidges
Hi, Linda
You may buy cartriges of different producers.
Depending on producer on them can be or be not special yellow detachable labels.
These are an yellow labels must be removed from them. Then put cartridges back. And try to clean head 4-5 times. And check nozzle test.
Good luck.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
Magenta ibk problem
Have you tried running head-cleaning cycles? If not, try 2 or 3 followed by a nozzle check and see if magenta starts to appear. If this still produces no magenta print, or you've already tried this with no success, report back.
Feb 01, 2009 | Epson Stylus C84 InkJet Printer
C84 not printing
I assume that before the old cartridges ran out of ink, everything was printing normally. If so, the usual reason for this problem after a cartridge change is getting air into the print head system. Did you do a proper cartridge replace process, which finished with an ink charging cycle? Have you tried running 2 or three head cleaning cycles? If not do it, then run a nozzle check. Any sign of ink - yes - then things are OK you've just got to get the ink flowing properly. Run a couple more cleaning cycles then leave it to rest for 24 hours to let the air bubbles disperse. Then try again.
If you get no sign of ink after these processes report back.
Jan 18, 2009 | Epson Stylus C84 InkJet Printer
Everything is coming out pink
one of your ink cartridges is low. Annoying I know, since its not empty, but happens a lot.
Dec 14, 2008 | Epson Stylus Photo R300 InkJet Printer
Printer does not print
An ink supplier advised turning off the printer for 15 minutes, turn it on and try again. That worked once. Next time he suggested turning off printer, removing all cartridges, waiting 15 minutes, replacing cartridges. I couldn't do this without turning the printer back on and going through the replace cartridges routine. Now the nozzle check routine printed magenta and yellow only. I've run the head cleaner a number of times with no success.  Hope one of these suggestions works for you.
Jan 06, 2008 | Epson Stylus C84 InkJet Printer
Printer not printing
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Nov 29, 2007 | Epson Stylus C84 InkJet Printer
If any of the ink cartridges are needing to be replaced, the Epson C84 will not print, you will have to change the cartridge, if you lift up the printer lid the carrier will stop at the empty ink colour.
Nov 14, 2006 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
131 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
