Question about Kenmore Elite Oasis 27052 Top Load Washer
When the washer spins the drum sounds like an airliner it also just started making a banging sound I can feel the banging on the right side of the washer
  • 50 Answers
Try load it a little lighter and spread the clothes more evenly (in other words so that the weight is not all on one side.
Posted on Sep 06, 2010
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
My washing machine make a rapid banging sound whilei spin cycle
Are you sure your machine is level and the clothes are not piled to one side. Alot of times this is caused by the weight of clothes more to one side of the drum then the other causing the machine to bang as it spins
Dec 30, 2010 | Amana ALW480DA Top Load Washer
Miele W1926 washer makes a banging sound when it spins
if i were you fist of all open door then you will see the silver drum on the inside lift the silver drum upwards from the top of it and if you feel a knocking sound then the bearings have worn out expencive to replace them,as sometimes you have to have a complete new drum.rgrds,paul
Jul 07, 2009 | Washing Machines
Loud banging/thumping during spin cycle on my kenmore front load
this sounds like this could be the bearings,to check for this,open door and with yourhand lift the inner chrome drum and let it fall then lift again and if you feel a knocking sound and a lot of play in it then its the bearings,i know there should be movement in the drum but this will feel more of a knocking.
Jul 06, 2009 | Washing Machines
Horrific banging when in the spin cycle
There are a series of balancing springs connected to the drum. It sounds as though one of them has come off or loosened. Yuo'll need to turn the machine on its side to find out. Good Luck! Let me know how you make out.
Jun 08, 2009 | Kenmore 43042 Front Load Washer
AEG LAVAMAT W1450 SOMETHING LOOSE IN DRUM WHEN SPINNING
Sounds like the main drum bearings have gone, if you hold the the drum and can feel up and movement or it sounds noisy or rough when you turn it by hand then it is definately bearings gone.
Unless you know what you are doing ,I would not recommend a D.I.Y. repair.
Dec 14, 2008 | AEG Lavamat W1450 Front Load Washer
Drum is sparking when spinning the clothes
Sounds to me as though the main drum bearings have gone and the drum is catching the internal parts.
I f the drum is turned by hand and it feels rough or is noisy, then it is the main bearings.
Sep 24, 2008 | Creda W120VW Front Load Washer
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
87 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
