Question about Ingersoll Rand Compressors 5-HP, 80-Gallon, Triple Stage Rota
Hi, whats the oil capacity for an ingersoll rand compressor? serial: G9874V02140 model: SSR-EP50SE 215 CFM nominal drive motor 50HP we are about to make an oil change[thank you]
    Novelist:
  • 210 Answers
Below is the procedure for COOLANT change including amount needed.
SSR Ultra Coolant (Standard Factory Fill)
SSR Ultra Coolant is a polyglycol base coolant. Change
Ultra Coolant after every 8000 hours or every two years,
whichever comes first.
In addition to the tools normally found in any reasonably
equipped serviceman's toolbox, the following items
should be available at the work site:
1) Suitable drain pan and container to hold lubricant
drained from unit.
2) A quantity of proper lubricant sufficient to refill the
compressor.
3) A minimum of one replacement coolant filter element
of the proper type for the unit to be worked on.
There is a coolant drain valve on each compressor. It is
located on the bottom of the separator tank.
The coolant should be drained soon after the compressor
has been shut down. When the coolant is hot, the
drainage will be more complete and any particles in
suspension in the coolant will be carried out with the
coolant.
Hot coolant can cause severe injury. Use care when
draining separator tank.
To drain the unit, place drain pan under drain valve. Open
drain valve to start drainage. After draining is complete,
close drain valve.
After the unit is drained and a new coolant filter element
is installed, refill the system with fresh coolant through
the filler cap on the side of the separator tank. Bring the
receiver level of coolant up to the top of the sight glass.
Replace the fill cap. Start the compressor and allow it to
run unloaded for a short time. The correct coolant level is
at the midpoint of the sight glass with the unit running in
the "UNLOADED" mode. If the level is not near the
midpoint, stop the compressor and allow all pressure to
relieve from the system. Open the fill cap and add more
coolant.
50 hp (37 kw).....................3.4 gallons (12.9 liters)
Coolant fill quantity
! WARNING
Use care when near this area.
Use only recommended
coolant.
Read instruction book
before servicing.
39543921
run unloaded. The coolant level should now be near the
midpoint of the sightglass.
DO NOT OVERFILL THE MACHINE. Over filling will
affect separation and carryover down stream.
Posted on Jan 21, 2011
Why is oil being sprayed on the inside of the air filter ingersoll rand air compressor ssr-ep50se
you're oil separator has failed or the machine is not scavenging back to the compressor
Oct 17, 2014 | Air Tools & Compressors
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
I'm working on a Ingersoll rand 100HP stationary compressor with an intellisys 39875158 controller.
Make sure the model of your compressor is design for 160psi if not the main motor trip off and safe valve pop. Goto Main Menu, Operator setpoint+select, Offline/Online+select, arrow up and down to change value.
Jul 04, 2012 | Ingersoll Rand Stationary Air Cooled...
What does alarm start fault mean on the control panel on a ingersoll rand ssr ep-30 air compressor
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Mar 28, 2011 | Ingersoll Rand Stationary Air Cooled...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Ingersol rand model 3000, serial no 9835350,size 5.5"&5.5"&4"x4",would like to know pumping capacity per/min
If the motor is a 20 horsepower it is pumping app. 80 cubic feet per minute . Here's a good rule of thumb 4 cfm per horse power.
Aug 05, 2009 | Air Tools & Compressors
Ingersoll Rand Compressors  5-HP, 80-Gallon, Triple Stage Rota Logo
904 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
