Question about HP Photosmart 2610 All-In-One InkJet Printer
Scanner problem hp 2610 scanner stops in the middle of the glass on the return when just copying any thing
    Novelist:
  • 79 Answers
HI,
In case u have installed the software on your computer , u can look for hp director on your pc ,
when u open p director > click settings > printer settings > printer settings > printer tool box > under that window > u will find service product tab , simpy click on that .
in case it does not help or u cannot find it .>
u can press set up on the printer > go to the tools option [ by pressing the down arrow key ] > press ok > go to clean print head , clean cartridge , allign printer > it will service the product .
u can reset the printer to its factory deafults as well
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6 .
But do not use the reset frequently.
Posted on May 29, 2008
There is a line down the middle of all pages when copying. The quality of the copy is fine otherwise.
Sounds like the glass for the scanner portion might have some gunk on it. Because the page moves across the scanner, a dot on the glass translates to a line on copies. There is usually a button or a handle to pull to get access to the entrance of the scanner portion of the machine. With a flashlight, inspect the glass at the scanner portion input carefully and use a paper towel and watered down windex to glean off any spots.
Jun 01, 2011 | HP 640 Inkjet Fax Machine
We have canon ir2000 Once when we switch on the machine, the scanner was below the reader glass but scanner was not moving while reader motor (scanner motor) was trying to move the scanner. After that we...
i cant get ur problem .it might be due to home sensor problem.try to use a air blower to blow the optics unit for dust . if that doesn't solve the prob then u have to call a tech as ur scanner may be out of home position and a tech will be needed to solve that
Jun 01, 2011 | Canon imageRUNNER 2000 Copier
I can copy a paper, but then the message comes on saying scanner failure, turn off and back on
HP Photosmart 2610 All in one Ink Jet Printer
I can only print, message says scanner failure turn powere off and on , I do this and it does does not reset
Nov 16, 2009 | HP Photosmart 2610 All-In-One InkJet...
Scanner says I need to install software
To make your scanner work use HP image Zone (included in your install cd or downloadable from hp's website)
Hope this helps
Jun 27, 2009 | HP Photosmart 2610 All-In-One InkJet...
HP OfficeJet 7310 - scanner stopped working
Do these tests. Try coping form the glass and ADF tray. If it works from the glass and not the ADF tray then you have a bad scanner motor assembly.
Michael
Perfect Printer Parts
Jun 18, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Making a copy
Open the document feeder and clean the scanner glass.
Feb 26, 2009 | Office Equipment & Supplies
Lines down middle of copy and fax
You probably have a bad SCANNER ASSEMBLY.
Try opening up the document feeder and cleaning the scanner glass
Jan 21, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
"scanner failure"
see if you can access the internal workings of the scanner, and see if there is something blocking either the track the the light is moved by, or the rail that holds the whole thing together. Also see if there is something preventing the cables that are attached to the light from fully extending.
Feb 21, 2008 | HP Photosmart 2610 All-In-One InkJet...
Yellow band when coping & scanning
this is problem with your scanner it is good if you can get servicing of your all in one printer
Sep 22, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
