When i dial some where i get eco sound - Computers & Internet
    Guru:
  • 689 Answers
Is that "Skype"?--Thats normal sorta "reverb"
Posted on Sep 06, 2010
When I turn my tv off, do I have to turn off the vizio soundbars or can I leave it on.
Eco Power On/Off Eco Power On: Eco Power Off: Press the Next/Previous button to enable/disable Eco Power Mode. When enabled (On), the Sound Bar will go into standby after a period of inactivity. The sound bar will automatically turn off when no audio signal is detected. Off disables this feature. Note: Enable this function if using a TV remote to control the sound bar.
http://cdn.vizio.com/documents/downloads/accessories/S4221W-C4/QSG_S4221WC4.pdf
Jun 30, 2016 | Vizio VSB210WS Soundbar
How do I get a dial tone?
Is the base station plugged into the phone jack on the wall?
May 17, 2014 | Swissvoice Epure Full Eco Cordless...
Logixx 8 beeps at the end of the wash cycle
Start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now.
Oct 21, 2012 | Washing Machines
How do I stop my Bosch logixx 8 from beeping endlessly at the end of a cycle?
hi, I found out last night after being wokenup by endless beeping.... start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now....
May 09, 2012 | Washing Machines
Pilot will not light
Unable to light pilot Gas supply turned off Turn on gas supply Gas **** knob dial not positioned correctly Check lighting instructions. Set control knob Defective thermocouple Check and replace thermocouple Defective safety magnet assembly Check and replace gas valve Pilot burner orifice clogged Clean or replace Pilot tube pinched or clogged Clean, repair or replace Poor thermocouple connection Check and tighten Air in gas line Purge air from gas line Thermostat's single use ECO is tripped Check ECO and replace gas valve Gas valve defective Check gas valve
Jun 06, 2010 | American Standard AMERICAN STD 100G NGAS...
Stem is broken watch cannot be wound
An Eco-Drive does not need to be wound. It has a rechargeable battery in it that is recharged by light hitting the dial of the watch.
All Eco-Drives have to be allowed to get light on them to recharge the battery. If they are put in a drawer or covered all the time by shirt sleeves then the battery will drain and they will not work.
If the battery is completely drained then the battery will not be any good and will need replacing by a qualified watchmaker.
Try setting your watch under a light or in a sunny spot with the light shining on the dial. If in the sun light it should take a few hours to charge the battery. If under a light it can take more than 18 hours to fully charge the battery.
But if the charging does not hold then the battery is no longer good and requires replacement by a qualified watchmaker.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 09, 2010 | Citizen Eco Drive Largo AT0424 59E Gents...
How do I find out on my watch how far from leap year we are .its acitizen eco-drive
Pull out the crown to position 1 and the second hand moves to the month position while the small dial moves to the years since last leap year position.
If you haven't got a manual to fully understand what the indications mean, go to "citizen.com", click on "Technical Support"amd then on "setting instructions".
Enter the number required off your watch and click on "get setting instructions".
Jan 31, 2010 | Citizen BL5314 52E WR200 Eco-Drive scyba...
Citizen Eco-Drive
Could be that the watch inside and outside numbers do not match. If the dial says Eco Drive, that should be the first step. Next, find out about the 4 digit number that tells you which type we are looking at. You may want to open the back and look at the number on the watch internals. But be aware you may damage the water proof seal in doing so.
Really, you should write down all numbers you can see and send an email to citizen. They will help you.
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
Jun 09, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Setting sub-dials when several months wrong
Try the manufacturers web site, you can normally find all the information you could require
Dec 11, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
