Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
My Futura ce-250 has started beeping error code 88 & continuiosly flashing all lights every time the needle reaches its highest position. It will not sew or embroid. The manual suggests the code & lights are 'machine malfunction'. Has anyone had this problem? I'm wondering if it's a broken sensor of some sort? how did you fix it? Thanks....
SOURCE: needle breaking-CE 250
I had that same problem and it was due to the thread being too tight. Put the thread net on your thread and it should be ok.
Posted on Dec 25, 2007
  • 97 Answers
SOURCE: Thread break warning when thraed is fine
Try switching to a higher quality thread, and blowing out the upper assemblies with canned air. (Making sure the machine is turned off before you do so.) Many problems are associated with low-quality thread, (Coats and Clark is the worst offender in this category.) Set your tension to about 4.5 and then try sewing again.
If this doesn't help, you may have a bad sensor, which would require service.
-R
Posted on Sep 10, 2008
dupina
  • 110 Answers
SOURCE: A brand new Singer Quantum
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Posted on Dec 08, 2008
  • 23 Answers
SOURCE: I have a Singer Futura CE-250 and when I am
Try Gezina Sewing machine I find they are very helpfull.
(012) 335 0636
Posted on Feb 27, 2009
  • 5 Answers
SOURCE: The needle constantly breaks while embroidering.
My foot does this with different thickness of fabrics, it will make the foot land in different, areas, sometimes making the needle hit the foot. Always check needle position before you start embroidering. once your hoop is ready, check the clearance. I often have to use a small roll of non slip material under the foot handle, the one used to bring the foot down. And I use this to adjust the needle postition so it will always land in the middle of the embroidery foot. There is also a way to adjust the height of the needle arm but that's too complicated to get into here and I've never personally tried it.
Posted on Oct 20, 2009
Error Code 88 - when I adjust the embroidery unit
Usually the owner's manual will list the most common error codes in the Troubleshooting Section. It is difficult for anyone to help diagnose your problem without the make and model of your machine.
Here are a couple of web sites that may be helpful:
http://futura-support.com/node/108
https://www.youtube.com/watch?v=2YeDNwJDV_k
https://www.youtube.com/watch?v=DVJIPCK-LcM
https://www.youtube.com/watch?v=8TXtX_uUaww
There are more videos available through YouTube re using your machine. If the above didn't help, there may be others that are more helpful.
There may be something in these reviews:
http://www.amazon.com/Singer-CE-200-Quantum-Futura-Digitizing/product-reviews/B000N5KFN4
Nov 05, 2015 | Sewing Machines
I cannot thread my bobbin, I can sew. When I try to thread the bobbin, Code 88 starts flashing.
You said "trying to THREAD the bobbin." Did you mean it happens when you put an empty bobbin on and push the spindle to the right? Is your needle all the way up? If so, pull the buttonhole lever ALL the way down, then smack it up, and check to make sure the twin needle lever is not selected. Frankly, I'm not in love with that system anyway; you might think about purchasing an inexpensive Sidewinder for less than $20. You can order from WalMart online; if you pick it up at a WalMart or FedEx facility like Kinko's, shipping is free. Believe me, you'll do yourself a favor; many problems with these machines are actually caused by loosely wound and/or badly wound bobbins. Also, think about purchasing prewounds; they're actually cheaper than winding your own.
Jan 18, 2014 | Singer CE-200 Quantum Futura Computerized...
Thread my bobbin, Code 88 starts flashing & all lights
I owned a CE-200 for about six years, and as I recall, that code blinks if your needle is not all the way up. If it is NOT up, operations are suspended until it is. That means that the hoop cannot reset to its default position.
Jan 17, 2014 | Singer CE-200 Quantum Futura Computerized...
Singer quantum futura ce200 - thread breaks
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 06, 2012 | Singer CE-200 Quantum Futura Computerized...
Bobbin case keeps popping out of my CE-100 Futura. Not sure whether or not the case is in there correctly.
Raise the needle to it's highest position and the case should go right into the shuttle.
Refer to the maintenance section of the manual for your machine.
If you do not have a manual, you can get one at the Brother website.
Apr 01, 2010 | Singer CE-100 Futura Computerized Sewing...
Singer FUTURA CE-250 beeping at startup.
you have a bit of cotton blocking a sensor or lever. normally the one that tells you ran out of cotton.
Oct 03, 2009 | Sewing Machines
My futura sewing machine seems locked up
Try removing the screws that hold the needle plate on and take it off, remove the bobbin case and check for loose thread in the bobbin area. Sometimes machines lock up when a small piece of thread gets under the bobbin case, this is called being "thread locked". Hope this helps. I'll see what I can find out about the "88" error message.
Feb 24, 2009 | Singer CE-200 Quantum Futura Computerized...
Straight sewing but only a few stitches before stopping
Hi Gaden....It's obvious by your post that you have advanced knowledge in sewing/machines including maintenance, so I feel very confident that your issue can be resolved by updating your software. Please click on the URL below, and download the approriate updates that correspond with your equipment.......Please update your post so I'm aware of your status....good luck my friend http://futura-support.com/downloads/patch.htm
Aug 02, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
186 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
