Question about Traxxas T Maxx 3.3 Monster Truck
3.3 cranks but will not stay running nor idle help pls?
  • 88 Answers
I would start by replacing the glow plug. Make sure the carb settings match the factory base line settings.
Posted on Oct 02, 2010
2010 Ford F150 would suddenly loose power and only idle. Pull over shut off sit a couple minutes crank and run fine for a while then do same thing again. Wrench would show up on instrument panel
Sounds like the catalytic converter or muffler maybe getting plugged up and the computer is putting the truck in limp home mode. Did you put a scanner on the truck. You might try to remove the 02 sensor ahead of the cat and see if it runs a little better it will not be perfect but should stay running if so do an exhaust check. When the cat or muffler gets plugged it puts back pressure on the engine and won't allow the fuel to be pulled into the engine properly.
May 19, 2017 | Ford Cars & Trucks
1992 mercury grand marquise dies after letting off of the accelerator
Is this engine equipped with an EGR valve? Might have carbon deposits blocking the passageway causing the stalling problem.
Mar 06, 2014 | Mercury Cars & Trucks
Takes long to start in the morning
Is the "check engine" light on when the car is running ??
Jan 19, 2014 | 2000 Ford Taurus
My 99 dodge durango wont stay cranked without holding down the gas and it only happends when it the motor is cool and after holding the gas down and reving the motor for about 10mins or more it will stay...
hey that sounds familiar!have you checked your idle control sensor? let me tell you 1st you crank it cold,you have to keep your foot on the gas pedal until it warms up.but then when you come up to red light quick stop,the engine dies or wants to stop? sometimes it starts fine? but when it does,after running for a few minutes,it idles up and down? when it's warm after driving 15miles or so,you shut it off and try a restart,and the engine starts,but idles up and down? all of the above are signs of a bad idle control sensor.the part costs about $20.00 u.s. 2bolts removal 1 PLUG IN REMOVAL you may be able to do it yourself.have an autozone or advance autoparts store employee show you where it's located.you would be shocked at how many great people there are left in the world! i'm answering your question for free at midnight from the u.s. think i'm bored? no. just love helping people like you! thank you so much!
Jan 26, 2011 | 1999 Dodge Durango
Have 92 Accord LX idles low when running and problem cranking
does it have a throttle body or fuel injection?
Jun 27, 2009 | 1993 Honda Accord
92 corsica wont stay running. cleaned MAF with spray!
the maf on it isnt used a maf only a temp sensor the software change made the syatem speed density controlled fuel.. but if you have a idle probel it may just be the Idle Air Control Motor or IAC try to put foor on the gas pedal a little whne cranking see if it fires right up if so suspect the IAC.. is if still cranks long time try the fuel filter but those usually will make lack of power before you get a hard start issue.
Feb 04, 2009 | Chevrolet Corsica Cars & Trucks
2000 pontiac grand am- cranks but wont stay running, cuts off while driving
Its either Youur Alternator which is the more likly solution and any part store will help you test it free if thats fine then its a fuel problem
Dec 09, 2008 | 2000 Pontiac Grand Am GT
93 yukon 350 wont stay running at idle
when you crank the engine do you see fuel spraying from injectors .if you dont check for power at injector connectors one side should power and the other will be ground controlled from pcm.you can test with a 12 volt test for both. first test with test light grounded for power then test with test lead clip to battery to pos to the other wire from pcm while cranking engine light should flash.if it does turn key off again lean over tbi and have somone turn key on and listen for fuel circulating through tbi unit if you hear it without cranking engine replace fuel pressure regulator.
Dec 02, 2008 | 1998 Chevrolet K1500
Traxxas T Maxx 3.3 Monster Truck Logo
255 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
