Question about Compaq Presario 700 470024-192 Notebook
I have a good day estimated presario 700 laptop and I need help because they will not start, I connect the power supply and keeps the battery light turned amber, in conjunction with the direct power. no signs of turning. I can do?
    Sergeant:
  • 172 Answers
Unplug the power cable from the laptop
remove the battery then press the power button for 5-10 secs
plug in the power cable to your laptop WITHOUT the BATTERY
try to turn on your computer if still doesnt work try a known good A/C adapter if still doesnt work then mobo needs to be replace
Posted on Sep 06, 2010
Compaq presario C301TU laptop no power
Remove the main battery and try to power up, if it works replace the battery, no change! remove one stick of ram memory and repeat keeping one stick at all times, if none of these work the problem is more than likely the motherboard.
Jul 28, 2012 | Compaq Presario 700 470024-192 Notebook
Computer freezes right after start up
Try to turn off the laptop. Remove the cables and battery on it , press and hold the power button for 8 secs. Then reinsert the cables and battery on the laptop. Turn it on, then check if the pc freezes up. If it is, check if your keyboard has lights on it. If there is no lights, need to call compaq to replace the motherboard. If keyboard has lights and you dont know how to remove the parts inside your laptop, you still call compaq to replace the power supply or the video card of your laptop.
Aug 11, 2010 | Compaq Presario 700 470024-192 Notebook
Power problem I closed my Compaq F700 and opened it 10 minutes later and it shut itself down and won't power back up. Battery is good and the power cord light comes on when plugged in. Any help? Thanks...
Press the power button and if it goes on keep pressing the button until it shuts off. Then try to power it up by tapping the power button once.
How have you tested the battery? In my Acer laptop I'm on my third one in 2 years and recently got a 9 cell high capacity one that lasts 3.5 to 4 hours when my original lasted only 1 or 2 hours tops.
Jul 22, 2010 | Compaq Presario 700 470024-192 Notebook
I have a compaq presario 700 laptop that is no longer charging.
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
Insert the battery into the battery compartment on the bottom of the notebook PC.
2.
Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
Unplug the AC power adapter cord from the notebook PC.
4.
Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning properly.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Apr 14, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
Laptop wont start ... ( Presario 700 )
chk your ac adapter bro .. i think its not working
Aug 27, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 wont stay on...
Hi ,
this is problem with battery backup if your battery backup is not sufficeint for laptop it goes standby mode .....
please do one disconnect battery from laptop connect power Adapter to laptop & turn on laptop thrugh adapter supply check it out if your laptop is not getting standby you need to be replaed battey ...
If this Information is useful for you please rate me as you wish......
Jun 10, 2008 | Compaq Presario 700 470024-192 Notebook
My compaq presario v 5000 turns on for 3 seconds
Check the battery light if it is flashing is is dead other than that try unpluging the batter of 1 day and let is reboot the memory inside you will not lose anything.
Feb 17, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
67 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
