Question about Kenmore Elite 45986 Front Load Washer
Code what is the hf code mean washer starts and then goes into hf code
  • Anonymous Aug 13, 2008
    I have the same problem with HF & DF my door will not open?
  • 5,911 Answers
"F/H" this indicates that either have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on (not trying to insult your intelligence, but I've seen it happen).
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub check the following:
- Make sure you don't have a siphoning problem. Click the following link for intructions:
- Verify Drain Pump operation.
- Verify flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls that explains all the error codes and how to troubleshoot. It also explains how to perform diagnostics and where to locate certain components.
I hope this provides you with some aanswers. Please post back if you can't find the tech sheet and/or need further assistance.
Posted on May 13, 2008
Kenmore elite smart wash quiet pak hf code
i think the hf means heater fault,,,,,,,,,,,,or the thermostat
Jan 27, 2015 | Kenmore Washing Machines
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The code HF came up
I believe the code HF is telling you that you are not getting hot water. Check faucet in back and make sure water is turned on at both hot and cold valves. Even if you only use a cold setting, the hot water needs to be turned on. Also check washer fill valve screen. Turn off water and take off hoses at washer. Inside valve are sceens that may be clogged.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hf error message
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to where they have very good and complete trouble shooting and repair information on front loaders. You can search for the meaning of the error code on the site. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Washing Machines
What does a flashing code HF mean? This is a kenmore elite HE3t washer. thanks
That is the code for a water inlet issue.  Meaning "no or insufficient water supply" according to the manual. It says to hit PAUSE/CANCEL twice to cancel cycle. Then unplug unit and check for:
Are faucets completely turned on? Are screens at the inlet hose connection to washer clogged? Are inlet hoses kinked? And last...Are inlet hoses frozen? After checking all those it says to plug back in, re-select cycle and press START. If problem still comes up call for service. I remember on another site someone had the same code coming up, all the inlet suggestions checked out OK and they had to call for service as it was something in the control panel/computer of the unit.
Hope your issue is something simple as suggested by the manual. Take care ; )
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite washing machine
This code means its not getting a sufficient water supply. I was doing a cold wash and noticed it was sucking down some hot water, so shut off the hot. MISTAKE, after a little bit the HF code came up. Apprently it likes to decide for itself just how cold is cold. Darned Computers.
To make a short story long, when I shut off the hot, it apparently shredded the washer and sent the remnants down to the little filter thingy at the washer itself, whereupon they reassembled themselves into a clog, once again giving me the HF code.
(Check your user manual Troubleshooting section. I think it says to press Pause/Cancel twice)
Mar 30, 2008 | Kenmore Elite 45986 Front Load Washer
Hf code
You need to be more specific. When does the code appear? Does the machine start?
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
262 people viewed this question
Sal De
 Brian Main
Brian Main
