Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kemore gas stove model: 790.72863301 - oven will light and begin to heat. Not sure it it is reaching set temp. Gas shuts off, but oven will not always re-ignite.
bigg t
  • 640 Answers
SOURCE: Oven Heat
THE OVEN SWITCH IS BAD ITS STAYING CLOSED.FAIRLY EASY TO REPLACE AND NOT THAT EXPENSIVE.ANY APPLIANCE STORE CAN ORDER THE PART OR YOU CAN FIND IT ONLINE.
Posted on Aug 29, 2007
docjohn174
  • 943 Answers
SOURCE: Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 08, 2008
SOURCE: Wolf Model R364G has a delayed ignition in the oven
yes it will applie to to second owner.
Posted on Dec 06, 2008
Macmarkus
  • 2605 Answers
SOURCE: Kenmore gas stove, broiler works but oven won't
Hello, I'll start by saying this may sound odd considering the info you provided, "ignitor glows...". It is actually the ignitor you'll need to replace. Being that I do service for sears I've replaced numerous ignitor's, both bake & broil, but bake being most common as it is typically used more frequently. I'll try to explain... The simpliest way to put it is this, the hot surface ignitors function like a large resistor. As the ignitor glows it reaches a value to allow the gas valve to open and lite the burner. If the ignitor is even slightly worn/off it won't ignite the burner, hence it need's to be replaced. Hope that help's explain what & why. If so please take a second to rate the solution I provided here at fixya. Good luck and thanks for visiting fixya. Macmarkus :)
Posted on Dec 11, 2009
  • 189 Answers
SOURCE: Kemore gas range model #790: oven does not get
Hello- Sounds like lower burner ignitor is bad. Resistance should be more than 4ohms. across ignitor. Parts available locally at app. parts store for 50-75$. Fairly easy to install. - Hope this helps. Thanks- ED
Posted on Feb 28, 2010
Testimonial: "Thanks!"
Kenmore oven shuts off before preheated
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Mar 21, 2014 | Ovens
Samsung NX58F5500SS 30" gas stove 'door' light blinking and temp unregulated
-possibly temperature sensor has bad connection. Or bad sensor.
Good luck
mai
Dec 19, 2013 | Samsung Kitchen Ranges
Oven will not reach desired temperature and slight gas smell
Just had same problem it was nice it waited until christmas dinner, all i did to resolve the problem was switch the upper broiler igniter with the lower one for the oven. I tuned on the oven & it fired right up i never use the broiler on my oven so itll buy me some time. So if you can get the broiler to light try that but i did have the same low temp. & the smell of gas. Good Luck
Jul 29, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
A wire is hanging from the stove top down into the oven with no where to go. The stove is an old gas Kenmore slide-in. Will the house blow up if I use the oven? Any idea what this wire is for?
Are you sure that it is a wire ? It could be the capillary tube that has had the bulb broken off. The t-stat has a hollow tube (capillary) with a bulb on the end that senses the temp in your oven & tells the oven when it reaches the set temp to shut the heat off. The bulb usually is found towards the top of the baking chamber on either side or at the back. If this bulb is broken off, the t-sat needs to be replaced. There should be NO wires inside the oven, all wiring is routed on the outside of the baking chamber & is protected from the heat by a blanket of insulation.
Jul 09, 2009 | Ovens
I have a Frigidaire Gallery gas range and oven #plgf389aca
i need to shut off the self cleaning on my stove.
Dec 11, 2008 | Kitchen Ranges
Model # fgf347awj propane oven will not pre-heat.
Sounds like gas valve is bad and the thermostat also. I would change the gas valve first. But when you said oven would not lite sure sign the gas valve is bad. New gas valve is about 50ish t-stat could be another 20. I would almost just get another gas stove at a used appliance store for 125 or something like that if unit is very old.
Nov 25, 2008 | Ovens
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
69 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
