Question about Ezonics EZCam Webcam
I don't have the CD to Install it to my computer
My computer will don't run cd to install my
you need to take off side plate then unscreww drive take out drive make sure that the ribbon on cd drive is off and power cord is off make sure that your computer is turned off first ok.than put in new cd drive rescrew drive in then plug in cables red side to pin one look at the back of the drive make sure that you put the cables back the same way you had taken off.
May 22, 2011 | HP Computers & Internet
I need to install my printer on a computer How do i do that ?
Hello paladin41
It is recommended to install first the software ( use the cdrom and follow instructions ) BEFORE connecting the device to the pc . If you don't have the cdrom , you can get the software/driver , free of charge , from here : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1141647&lc=en&cc=us&dlc=en&lang=en&cc=us
attention : select the correct OS before downloading .
Best regards ,
fanaudi .
May 08, 2011 | HP Photosmart C4180 All-In-One InkJet...
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
I don;t have any sound on my computer
First connect your spearker to your computer -
1. check you have installed your sound driver in your computer.
2. If there is no installed drivers install drivers from *********** board CD.
3. If you attached sound card in your motherboard, install CD which you have sound driver card.
4. Another option for drivers download from Internet and install in your PC
If not Work:
go to start - control pannel - sound & game controller - check sound balance
Feb 01, 2010 | Computers & Internet
My computer don t accept office installation
ok u can change your cdrom than after u can install the same cd. than after same problem u can face.u have to change the cd of office 2007. ok first u have to change your cd rom..
Mar 30, 2009 | Dell OptiPlex GX520 PC Desktop
Purchased a webcam without cd need to install on computer but don
Choose your webcam from the following list of phillips web cam then download and install your software:
http://www.support.philips.com/support/html/index_us_en.html#../~scripts/xsltransformsearch.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=us_en||mode=prods||item=WEBCAMS_SU||page=1||show=50&xsl=search_result.xsl
Jan 03, 2009 | Philips J44414
I need to install my printer to my computer but i don can
Try this. Before connecting the printer put the printer driver cd in the drive and install the drivers. If not asked to connect the printer, then restart the computer with the CD in the drive Connect the printer. Printer will be detected.
Dec 17, 2008 | Office Equipment & Supplies
Ezonics EZCam Webcam Logo
13 people viewed this question
Top Ezonics Computers & Internet Experts
micky dee
vojvodabudva
Rommel Balcita
Are you an Ezonics Computer and Internet Expert? Answer questions, earn points and help others
