Question about Kenmore 46123 Stainless Steel Electric Kitchen Range
Kenmore model 790.99012 burner is not coming on completely
When I turn on the front burner it only heats in the middle the outer part will not come on. Also it was only going up to 8.5 setting I took off the dial and put it back on which seemed to resolve the problem. Any ideas?
  • 311 Answers
SOURCE: The inner right front element
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
  • 1891 Answers
SOURCE: Kenmore 790 model series - WCI. Top left burner
if only one burner is at fault / probably is spark sw / replace alll four when replacing one this will save you some time next week . and some of the sw are on a wire harness with the 4 prewired .. hope this helps mm
Posted on Dec 04, 2009
SOURCE: Kenmore electric range 790. Both the broil and
I have the same problem... I checked both elements and they are fine. I was wondering if it was the ERC. Have you fixed yours yet? Please let me know.
Posted on Dec 06, 2009
SOURCE: one burner will not ignite, unless one of the
It was only a loose wire.. Thank you
Posted on Jan 07, 2010
GE Spectra Dual Burner not working.
the burner is faulty
replace just the upper part of the brner
or try to clean it
yourself
Sep 16, 2008 | GE Spectra JBP78 Electric Kitchen Range
Front right burner under stove top model 62960002603 only heats to LOW heat. It has a single, dual, triple mode setting and will not heat up to highest setting. HELP.
I looked up the model number you gave. It is a Kenmore range.The part number for that element is 7406P494-60. When you say it only heats to low, do you mean that only the center portion of the element lights up? Normally, when this occurs, it is an indication that the middle element and outer elements have a break. The problem could also be a faulty infinite switch(burner control). The part for that particular control is 7450P011-60. You will need a voltage/ohm meter to troubleshoot further. This can be a very INVOLVED repair attempt. I recommend, that if you're not comfortable disassembling your unit, call for service--this can absolutely be a tricky diagnosis and much care is needed to not damage the glass cooktop when checking the element. I hope I helped you.
Aug 31, 2015 | Kitchen Ranges
I have a kenmore elite range model no. 790.9911. The right front burner wont turn off. Is it the switch, burner or control board
On this model (with the glass touch controls, right?), it is usually caused by a bad, sticking relay on the relay board, located on the back side of the oven, down near the bottom. Some of these models had a safety recall... You might want to check to see if yours is one of the affected models. (The model number you gave is not complete; find the complete model # & serial # on the range itself, usually on the range frame, visible when you open the drawer or open the door.
Dec 13, 2014 | Kenmore Kitchen Ranges
Just purchased Ilve Ceran ceramic cooktop. Is V364X the cooktop model number?The outer are of the left front burner does not heat up
You may already be aware of this but ... If our ilve ceran cooktop is the same as yours turn the knob past the 12 setting till you feel pressure and it springs back. This is the switch to fire up the marked outer elements.
Mar 11, 2012 | Cooktops
Kenmore smoothtop model 911.9554590 duel size burners
the inner burner is broken so the whole thing needs to be replaced. check your owners manuel for warrenty times on the burner. otherwise just replace the burner and that will solve your problem..
Mar 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore glass top range left front large burner out
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
Nov 28, 2008 | Kenmore Kitchen Ranges
Kenmore Elite 790 Range
I can't believe I found this today. Today, my Elite 790 inner coil also stopped working! A little too coincidental.
When I turn on the burner, I can hear like a relay click on, but it does not heat. The middle and outer burners are fine.
Dec 20, 2007 | Kitchen Ranges
Kenmore 46123 Stainless Steel Electric Kitchen Range Logo
89 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
