Question about Sony Playstation 3 (PS3) Console
I repaired my Dad's PS3 (YLOD) by heating up the CPU & GPU then putting some Artic Silver on the processors. It worked. So I decided I was going to buy someones broken (YLOD) PS3 for about $40 I did the same thing and made sure I did it right. I'm still getting the YLOD until I physically compress the uncased system in my hands. I then get what I believe is the normal boot up green light then accompanied by a steady blue light, I then plugged in the video cables and get no picture. My first question; is there any way I can get the system to have no problem without physically holding the board to the heat sinks? Maybe I have to put some washers to make the heat sink closer??? Also, how would I get the picture to come up?
  • Jeremy Davis Sep 06, 2010
    Okay, thanks. I'll try one more reflow. I've done 2 so far. If that doesn't work I'll adjust the heat sink clamps. If that doesn't work I will assume that I'm screwed and use the rest for parts.
    I put some pennies under the heat sink clamps and it seems to turn on without holding everything together with my hands. So problem #1 solved, maybe. When it turns on the tv doesn't even recognize anything being plugged in (both HDMI and AV cable). I've tried holding the button down for 5 seconds, it doesn't do anything. I'm starting to think now that either the GPU isn't soldered down all the way or it's just bad.
    President:
  • 1,139 Answers
Ok first the heating up. You may find that the reflow did not quite get hot enough to melt the solder back onto the ball grid arrays enough. You could try another reflow and see if this works however every time you do a reflow you risk permanently damaging the CPU/GPU. The other thing you could try is bending the heat sink clamps a little to apply more pressure on the CPU/GPU but again this could cause more damage.
Secondly the display. If this reset sequence does not work then you have probably damaged the GPU in the reflow process :-
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Posted on Sep 06, 2010
  • Kevin Penn Sep 06, 2010
    If the video reset doesn't work then it certainly sounds like the GPU may have died during the reflow. You have held the power button down until you hear the second beep? If that definitely doesn't work then it looks like you may have fried it :(
PS3 yellow lite of death
What is your question about the YLOD? Typically, it happens for different reasons. Check your A/V connections. If they are not connected, you'll get the YLOD. 2, it has over heated, and has to be taken apart, heated by a heatgun to reform the solder, then new heat gel put on between the board and the cpu/gpu. Pretty easy really. Here is a youtube vid to get you started.
PS3 PlayStation 3 YLOD Repair the proper way to reflow your board
Feb 08, 2014 | Sony Playstation 3 (PS3) Console
After playing a disc for a few minutes, my Ps3 starts making a noise --constant low whirring sound as if the fan is on overdrive. Any idea as to what might be causing it?
if you have any of these gb consoles these are the first ps3s 20gb 40gb 60gb 80gb.okay these consoles are all dying.see when sony made these they did lead free solders for the cpu and gpu and they used crappy thermal paste on these processors.so now when your ps3 gets to hot or just old it heats up so bad that these solders melt and cpu or gpu come off motherboard its called ylod ur ps3 is in the process of going down at this point u can do nothing for it its pretty much done.u could try replacing thermal paste it may help but i think the damage is to far along to repair if u have the new models like the 160gb slim or 250gb or 320gb then i wouldnt worry about it.
Apr 17, 2013 | Sony Playstation 3 (PS3) Console
Hi ive just turned my ps3 on it stopped and went off now it wont play just got a red light when pushed it flashes green and blue the goes red when pushed again it flashes red help
Yes this is the YLOD the (Yellow light of death) it happens when the GPU and the CPU overheat and you will need to fix this by stopping the heat build up, you can sned it in and they will fix it for you for $130.
Or you can fix it yourself using a good PS3 Repair guide in under an hour!
Mar 07, 2010 | Sony Playstation 3 (PS3) Console
Hi i have been having problmes with my 80gb ps3 its had the yellow light of death 3 times and now some orange light is flashing after fixing the ylod is this the same thing or different any help?
hey cal
did you use silicone based artic silver
if so bake your board for about 2 and a half min at 700 to 900 degrees
focuse mainly on your gpu and cpu
go spend 10 bucks on artic silver from radio shack you will have a much better turn out
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
Xbox 360 has 3ROD w/error code 0020. It used to be 0102
Open your Xbox again, remove the motherboard and take off the heat sinks.
Clean the heat sink compound off of the the CPU, GPU, and both heat sinks using 91% alcohol. The CPU & GPU should be as shiney as a mirror when your finished.
The next step is to apply Artic Silver 5 Thermal compound to both processors using just enough to cover the processors, then put your system back together again and give it a try.
If it still doesn't work you may want to try to find someone who knows how to do a reflow. If you go this route, becareful who you choose. Ask for referrals and most importantly, ask for a picture of the equipment they will use to "attempt" to fix your Xbox.
If you get a picture of a standard Heat Gun... find someone else.
Be aware that even after a reflow, your Xbox is still subject to failure again. Microsoft can't even fix them permanently.
You're already familiar with opening your Xbox and taking it apart so you may want to consider learning how to do a reflow yourself.
There's also the option of buying a new Xbox but there's a good chance you'll still be facing another failure in the future. the difference will be that the new Xbox will be covered under warranty for a period of time depending on the problem.
I've heard that new consoles with a Jasper cpu tend to be more reliable but I've not seen any scientific data to back up this claim.
Good luck, I'm in the same boat with 2 broken and have decided to buy a reflow station to repair my own instead of paying Microsoft.
If you think this information is helpful to you, please take a few minutes to rate this reply.
Aug 29, 2009 | Microsoft Xbox 360 Console
Xbox 360 no sound no picture
did you check if your cable was switched from hd to standard or for any frayed or ripped wireing also check the connections it could be the tv is set to another channel just the small stuff like that or hold the power button the the xbox til it turns off
Aug 14, 2009 | Microsoft Xbox 360 Console
When i switch my console on, the red light comes on & when i press the standby button the light goes to green for a split second, flashes amber & then goes straight to red? What do you think the...
The problem is known as a YLOD on the PS3 or Yellow Light of Death. Your PS3 is most probably a 60gb model as they are mostly known for this issue. The PS3 is fitted with a very good cooling system. Unfortunately some of the 60gb models still overheats (either the GPU or CPU). This causes the YLOD and is very similar to the XBox' s Red Ring of Death.
The best is to return the PS3 if still under guarantee. You can attempt to repair it yourself at own risk. There are no statistics on how long the fix lasts. Most of the YLOD consoles I repaired myself are still holding out and it seems the fix is more permanent than the Xbox 360 fix. Here is a link to the guide that must be followed and it works (http://www.youtube.com/watch?v=4_Ic1_TY-GU) The other parts in the series you will find on the same page. There are 7 parts
After the fix a couple of things can be done to prevent future overheating:
Do not keep the PS3 in a confined space.
Keep it away from dust.
To enhance airflow, remove the cover over the HDD when switching it on.
Switch it off when not playing.
Hope it helps.
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
Ps3 is quitting by itself
Your system has overheated. The thermal compound has heated and moved away from the CPU/GPU and the heat sync keep the heat from being dissipated via the heat sync. Eventually you will get the YLOD which is the equivalent of the Xbox 360 RROD. This is due to heat sysnc problems. Your CPU and GPU will more than likely need to be reflowed. I got the YLOD on my PS3 around the first of March 09. I also fixed my PS3 in about an hour. I have had no problems since. You can slow the YLOD but i dont believe it can be stopped. It seems it will eventually happen to all PS3's. One tip do not stand the PS3 on its side keep flat. This will help keep the thermal compound from moving as much when it heats up.
May 16, 2009 | Sony Playstation 3 (PS3) Console
Turn the ps3 whait for too start and dosent
Hi There,
I have had this problem, as my PS3 is now out of warrenty i have decided to fix it myself, so if your PS3 is out of warrenty aswel i sugguest you do the following, if not then send it back to sony.
The problem seems to be a over heating, you will notice this as the fan kicks in to high power after about 10mins.
What you need to do is disassemble it, heres a guide that can help you: http://www.llamma.com/PS3/repair/PS3_disassembly_tutorial.htm.
After this you will see the CPU and GPU, the problem there is the thermal compound on it, its dry and cracked and not enough, u need to clean all this off and buy some Artic Silver 5 Compound, on ebay for under £5, you then need to place some on the CPU and GPU corner to corner then smooth it across with a card, as thin as you can! then put it all back together.
problem solved
Feb 16, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 overheating Fan problem?
I have done the research!!! And I wrote this guide taking more safety precautions against breaking my system than the originators so this is a reproduced guide wearing safety belts.
This means there are 2 possible problems with your PS3. Either 1) your fan is dying and needs to be replaced or 2) the heat transfer from your 2 processors to the fan is deteriorating. Number 2 is the most popular for overheating because Sony didn't use the greatest of thermal compounds on their processors, and the heat sink solutions Sony used in its launch systems weren't as well engineered as the later systems. 60gig are the most prone.
This has happened to me and I have fixed my PS3. It works perfectly as if I had just bought a new one (fan is super quiet, showing that the heat transfer is working perfectly) and 5 months later I had to repeat the process and it fixed the problem again. So, this solution may have to be an ongoing task through the years, I suggest doing it 3 times a year like I plan on doing. All you need is a couple screwdrivers, thermal paste (preferably something with silver or more expensive, Arctic Silver is good), and a heat gun (usually made for stripping paint) that gets to at least 650F. The processors in this MB are soldered in...
Okay, assuming you are good with handling hardware and get the PS3 bare down to its motherboard, you should see the huge *** fans mounted to the 2 processors, 1 says GPX and the other CELL I think.
1- You need to take off the fan carefully 2- Clean all the dust you can possible see, CAREFULLY 3- Use acetone or some other 99% alcohol compound to clean the old thermal paste off the back of the processors and the mounts of the fan. --------------------------------- This part is important --------------------------------- 4- Look for the 2 black chips that are almost touching each processor above (or below depending on the direction the board is) and pay attention to their location to the chips for when the board is upside down.
5- Place your motherboard on a flat, heat resistant surface and set up to where nothing will touch it for 30 minutes.
6- Using the heat gun, heat the processors for 25 seconds a piece (less time the hotter the gun) using a circular pattern as not to have the heat focused in 1 spot. Then do the same for the 4 black chips.
7- Let the motherboard cool for 30 minutes. You will hear popping noises, this is the solder hardening back up after being set further in its socket. DO NOT TOUCH MOTHERBOARD. It is hot and any outside pressure or contact could snap it. Just let it sit there.
Whats happening is your are resetting any connection damage that might have occurred from the processors getting hot and not cooling properly. This also corrects any minor misalignment of the processor and its seat.
8- Flip the motherboard over and repeat steps 6 and 7.
9- Now apply a thin layer of the thermal paste on the back of each processor. Just enough so you that appears like you can see through it. Not literally but to the point that you think you can make out a letter on the processor.
10- Mount the fan back on carefully and clean up all excess thermal compound that may have been squeezed out the sides.
That should do it. Put the PS3 back together, leave the final screws unscrewed, hold your breath, pray to your deity and turn it on.
Like I said earlier, this happened to me I. I did this fix, failed because I didn't heat the processors long enough. Increased my heating time by 15 seconds each processor, and then my PS3 ran faster, smoother, and quiter for about 5 months before I had to do this fix again because my girlfriend doesn't like to turn my PS3 off (have to shorten auto shutoff to 1 hour now *sigh*). But fixed for a second time with same results.
Good luck gents. This solution does work, but you must also know that it may void the chance of Sony fixing this for you for 150. I paid $7 (US) for the thermal compound and $25 for the heat gun. And the PS3 are $300
Nov 30, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
320 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
