I have motorguide lazer II electric trolling motor 52 RF 52 lbs of thrust with wireless remote foot pedal which no longer works. I wanted to know if I can replace with the new remotes now available? Foot control and hand remote?
4 Suggested Answers
  • 36 Answers
SOURCE: looking 4 a manual
This isn't my usual area of expertize, but is this what your looking for?
Minnkota 824 Motor Diagram
Posted on Mar 21, 2009
SOURCE: I nned a motorguide 46 lb. thrust electric foot
Go to http://www.boats.net. Let me ask you a question, is it 5 speed? And if so have you lost some or all speeds but 5?. I so, them you need to take the lower unit apart and you will find solder laying in the bottom. You will see that the speed control coil wires at one if the terminals on the brush board has no solder. Clean it up along with the wires so that you see copper and re-solder. This is due to poor quality control on soldering at the manufacturer. When you re-assemble tighten the bolt 45-50 in-lbs only. No more.
Posted on Dec 29, 2011
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
My motorguide x15 trolling motorjust wants to spin around .. it has a remote foot control
Define 'wants to spin around'?
The propeller motor is supposed to spin around :>)
If the whole motor unit is spinning around you need to clamp the motor stem.
For factory support, you can get that from the website.
Xi5 Trolling Motor Xi5 Wireless Trolling Motor MotorGuide
Jul 19, 2016 | MotorGuide FW71 FB Freshwater Series...
I nned a motorguide 46 lb. thrust electric foot controlled trolling motor manual
Oct 02, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
My Motorguide W75 trolling motor has a single black wire in the receiver case that is detached at one end. I need to determine where to connect it?
That is probably the antenna for the RF remote control system. Is there a connector on the end of the wire? Contact me at groshartl@gmail.com
Sep 07, 2010 | MotorGuide Motg W 75 Wireless 60"
Foot pedal on Motorguide is out of time with steering...
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
Jun 01, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replacement of motorguide trolling motor prop
Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
Triton72
Mar 26, 2009 | Boating
Motor guilde lll trolling motor
I have a motorguide trolling motor model 2600 #s/n 19409 can't find out what thrust it is
Feb 15, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Computers & Internet Logo
389 people viewed this question
David Payne
David Payne
