Question about Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP)
This si the second time I have had a problem when I changed tanks. It started working the first time but not this time. The tank valve is open and the pressure guage is in the green, until you tirn on the burner to light it, then the pressure guage goes to red (empty) and the burner lights for about 1/2 second then goes out from lack of gas. It worked fine until I changed to full tanks. As soon as I turn off the burner the pressure guage goes back to full ! Help please
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
Many newer grills have a safety feature built in where the valve will not
allow gas to flow if the burner valve is in ON position when the valve on
the tank is opened.
Try this - Shut of all valves, disconnect and then re-connect hose to tank,
turn on valve above LP tank, THEN turn on burner valve, light w/ spark or
match...
This feature can be really frustrating if you don't know it is in
operation...
Posted on Sep 09, 2010
Why wont my old grill work with new propane tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 13, 2014 | Weber Q Grill
Poor flame after changing tank on gas grille
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
I have a flotec 1 hp pump. Wife washed 3 loads of clothes in a row and noticed we run out of water a while later. I shut pump off and noticed pressure tank low on air. I put 18 lb. air in tank and...
If in the past your system can build-up pressure up to 40 psi even if the supply valve is open and water is being used in your house, then your pump impeller maybe already worn out that's why its pumping capacity was reduced.
Nov 12, 2012 | Flotec Corrosion Resistant Shallow Well...
Rear Fuel tank doesnt work so my 1990 ford f 150 2x4 custom long bed automatic, it has dual tanks that are connected to a switch on the dash board. The tanks have seperate pumps and connect to the same...
Hello
Having worked for Ford for 25 years and having seen this very same problem (fuel flows between tank and overflows) many times there is only one cause of the fuel flooding the other tank, the fuel switching valve on the frame rail under the truck is detective, this valve contains special silicone rubber poppet valves that open when the front or wear tank fuel pump is selected, it then seals when the tanks electric pump is shut off at the selector switch, your poppet valves are leaking, all to a common problem. Back in 2000 when I retired this switching valve was no longer sold by Ford parts, it is obsolete. I suggest you check with Ford to see if it is available from some other source or call a local parts store like NAPA or Carquest and inquire is anyone in the aftermarket has them. The last choice is a used one, but of course it could have the same problem as yours as age and deterioration of the rubber valves is what makes them leak.
Oct 31, 2011 | 1990 Ford F150
Does not start. manual start doesnt work either.
First, is your grill on a cart or built in to an island? Secondly, are you using a 20lb propane tank to fire the grill or is it hard piped to the grill from your house? And finally, has it been converted from Propane to Natural Gas?
If you're using a 20lb LP Grill Tank are you sure there's still gas in the tank? Did you just installed a new, full tank recently and the problem started after that?
If the latter is the case, turn off the grill tank valve and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY, until it's fully open. Light each burner one at a time and turn then to high flame. Do the flames look normal? Are they the proper height? Is so, you just solved your problem. Remember to turn the tank valve on very, very slowly after turning it off each time.
If you grill is hard piped from your house, be sure that the gas line shutoff valve is turned ON.
Hope this helps solve your problem.
Feb 15, 2011 | ProFire PF27G Grill
I have a Dukane Stainless Gas Grill (Five Burners, a Rotisserie and Stove top). It worked fine for three years. Now, I am not able to light more than one burner (of the five). When I go to put the second...
It's possible you may need a new regulator, but usually this problem is due to opening the propane tank valve too fast, which can cause the built-in excess flow valve to check closed to only a trickle. Next time you use the grill, very slowly open the tank valve and see if that solves it. If not, replace the regulator. Douglas
Sep 21, 2010 | Ducane 30400040 Stainless Steel Grill
The flame coming out of the burner bars is small
May likely be low on propane or propane tank gate valve not opened far enough. Otherwise sounds like faulty regulator.
Jan 16, 2010 | Weber Genesis Silver A Grill
Can't open valve on gas grill propane tank
I think she is talking about not being able to turn the valve on the propane tank...like its frozen. And it just happened to me as we'll.
Sep 29, 2009 | Kenmore Grilling
Grill wont stay lit
These new tanks have a safety device installed in them . If you open the valve quickly or tip the jug the damn thang won't work. Take the tank loose, open all the grill valves and close all valves. Reconnect the tank and SLOWLY open the valve a hair. Light the burners. No need to open the valve all the way. if you do the dumb safety will plug the jug.
May 08, 2009 | Brinkmann Charmglow 810-7600-S Grill
Got an old saeco magic comfort 7/8 years old -
bye a good coffee descaler not vinager follow instruction on it normally fill the water tank leave room for the descaler start the machine open side valve leave it running for 15 second turn it off let it site for 10 to 15 minute after open valve for 30 second let it site for 10 minute and open valve repeat untill empty tank after clean water tank very good that descaler is acid nasty stuff after fill the water tank full of water start machine open side valve empty water tank that its good luck pierre p.s it take a while do descale good but worth it
Jan 02, 2009 | Saeco Magic Comfort Plus Espresso Machine
Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP) Logo
249 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
