My Compaq V6000 will not power up. It looks like it's drawing power from the supply (little blue ring is steadily lit), the power button lights up when I push it, but it doesn't go any further than that.
  • 21 Answers
It can be that the RAM needs to be reseated. But if it is under warranty call HP tech support.
Posted on May 13, 2008
I have charged the blue tooth but I do not know how to turn it on to pair it with my phone
Well, try to press the Call button: it is the button that has got telephone drawed. Hold it until you see the blue light steadily lit. That means that you just turned on and putted the headset into pairing mode. Now find Motorola H500 over your mobile phone. You will need to put a pass, and it is by default (i think, on ALL Motorola Headsets): 0000. You're ready for using!
Dec 18, 2010 | Motorola Mobility Universal Bluetooth...
My lg phone says no device found
Ok. Take T305 in your hand. Hold the call button until you see purple light steadily lit. Then release the button, but when you see the blue light steadily lit, you're ready! Now try finding the device named: Motorola T305. The password is: 0000. Headset will check the password, pair you,and that's it! Good luck with using!
Nov 23, 2010 | Motorola Mobility Bluetooth Hands-Free...
How do I put my Motorola h505 in paring mode
Here are the steps to put it into pairing mode. Also please make sure you click the YES button below my response here to indicate my answer was helpful. It would mean a great deal to me if you could do so. Thank you
1. With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
2. If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Oct 11, 2010 | Motorola Mobility H500 Wireless Headset
My compaq presario V6000 is stop working out of blue..Don't know why..the power cable is connected but hit the power button,nothing happens..any solution ??
Disconnect all cables from the computer. Press and hold down the power button for about 20 seconds. Reconnect only the power cable and try to turn on the computer on pressing the power button If it turns on then good otherwise, switch the power cable of the computer with the power cable of the monitor as they are the same cable as the power cable could be bad but this rarely happens. Open the computer and see if you see any light on the motherboard, if you do then the power supply is bad. If you dont then both power supply and the motherboard could be bad.
May 03, 2010 | Compaq Presario 5000 PC Desktop
How do i set my my motorola h350 into discoverable mode
Plug the Motorola charger into the end of
the headset.
The blue indicator light turns on when the
battery is charging. It may take up to 1
minute for the light to turn on. When the
headset's battery is fully charged (about 2
hours), the blue indicator light turns off.
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
Oct 05, 2009 | Motorola Mobility H300 Wireless Headset
How do i place a h555 motorola bluetooyh in pairing mode
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Call button
towards the microphone to initiate easy
pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate
headset is in pairing mode.
Step B - SET YOUR PHONE TO LOOK FOR
YOUR HEADSET
On your Motorola phone, press (Menu) >
Settings > Connection > Bluetooth Link >
Handsfree > Look for Devices.
The phone lists Bluetooth devices it finds.
Select Motorola H555.
Select OK or Yes to pair your headset with
your phone.
Enter the passkey: 0000
Select OK.
When your headset successfully pairs and
connects with your phone, the indicator light
changes from steadily lit to flashing blue.
Troubleshooting: Make sure that any devices previously pairedwith the headset are turned off. If the indicator
light is not steadily lit in blue, turn off both the
other device and headset, wait 10 seconds,
then turn headset back on. Wait for the indicator
light to become steadily lit in blue, indicating
the headset is now in pairing mode.
User Manual
Aug 22, 2009 | Motorola Mobility Bluetooth Hands Free...
I need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
steadily lit.
again.
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
HIH
Jul 12, 2008 | Motorola Mobility Bluetooth Hands Free...
Blue light will not stay lit
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Jun 30, 2008 | Motorola Mobility H700 Wireless Headset
Blue Tooth
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the headset boom, repeat steps 1 through 3
Jun 26, 2008 | Motorola Mobility H700 Wireless Headset
I can not use my blue tooth
boom is closed)
Ensure that your phones blue tooth is active and looking for a new device
Jan 13, 2008 | Motorola Mobility H700 Headset
Computers & Internet Logo
David Payne
David Payne
