Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
I set my dryer time but when I go to start it, I get two dashed lines and it won't run.
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Dryer intermittently not starting.
The rat chewed up the power line and caused it to short out. Kill the rat!
Jul 14, 2013 | Whirlpool Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Kenmore dryer mod @ 110.67422600 won't start
Plan on changing this start-button.
Sep 15, 2012 | Kenmore Dryers
My LG Tromm electric dryer won't heat - again.
if the high limit is popping the dryer is getting to hot,i know you say you checked the vent line but i've heard that before,when i get out i remove the vent from the back of dryer,change out the t-stat and run it with the vent line off and it runs fine,how long is the vent line?if it's a long run remove it from the back of dryer and stick a leaf blower into it,blow it out to the outside and see what comes out,also first run it on air fluff,if this is a newer dryer set it to timed dry and then you can set it to air fluff,go outside and feel how it blows,then after you blow it out check it again,if you see alot of lint blow out and it's blowing harder your all set,you should take the dryer apart and clean it and the vent line once a year and you won't have any problems like this,also you won't have to worry about a dryer fire,your clothes will dry on time and less parts will have to be changed out,also when you get it to heat again run it on air fluff,if it gets hot on air fluff you have a shorted heater,one of the coils are touching the metal box on the heater and the heater won't shut off,also you have to clean out the duct where the lint filter slides down into,if this is blocked the dryer can't push the air out the blower wheel is blocked with lint.hope this helps you out happy holidays
Dec 25, 2017 | LG Tromm Electric Dryer
Gas dryer will heat sometimes and not heat other times kenmore model 72802
sounds like bad gas coils,you have to send the whole model number,it will start with 110. or similar,if the bottom panel comes off,remove it,start the dryer, or in the front panel down near the bottom pop off the cover and look in,if the flame lights and then after 10 to 20 minutes the flame doesn't light you have bad gas coils.when the coils are starting to fail they will work correctly until they heat up and then they won't work until they cool down,the coils are what opens the gas valve.the coils are on top of the gas valve,remove the two phillips screws,pull off the cover,remove the wires from the coils and install the new coils,put it back together and you'll be fine,also while you're in there,get a shop vac and vac out the cabinet,stick it on blow and blow all the lint off of the motor and out of the gas tube,then clean out the duct that the lint filter slides into.if your vent line is a long run from the back of the dryer to the outside,i use a leaf blower remove the vent line from the back of the dryer and blow all the lint outside out of the line,do this once a year,you won't have any fires,your clothes will dry on time and your motor and parts will last longer
Oct 28, 2011 | Kenmore 72802 Gas Dryer
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't start immediately after finishing one load. needs cool off time. and now, won't start at all! what should i do?
heatman101
Jul 24, 2011 | Dryers
My dryer won,t start. When you set the timer and turned the starter on you hear a sound that seems it will run but when you let go the starter it just won/t run
You have a bad motor. There should be a button you can press to make your dryer go while the door is open. Hold that and push the button in and then turn the drum. if that doesn't make it go then it is your motor
Apr 18, 2011 | Frigidaire Dryers
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
