Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
The focus has gone bad and cannot adjust via menue. What is circuit board number to replace is problem?
  • 505 Answers
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Posted on Sep 09, 2010
Vertical position does not work on remote. Magic focus on green goes half way stops then number five comes on screen. Hitachi 51inch rear projection tv
Magic focus on a Hitachi only adjusts at 16 points on the screen and needs to be done in a dimly lit room. Frankly its a sales gimmick, the number 5 means one of the sensors inside the screen for the Magic focus is not connected or bad.
Go into the tech mode for convergence with the original remote (that menu is called the Decam mode) and see if convergence will adjust there. There are close to 120 points that can be adjusted there as opposed to less than twenty in the magic focus mode.
Dec 23, 2012 | Televison & Video
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Sony post convergence repair problem
The flash focus is a joke in these sets--only adjusts a limited area and can make the set look worse--like having a cigarette lighter in your car--not really needed.
Flash focus rarely if chips have been replaced will SAVE the adjustments.
The set stores the convergence adjustments on a board inside--best way to adjust is with the Sony remote to enter the tech menu and adjust there--when done one of the numbered buttons is pressed and Save? in red appears--press same button again and it goes to green which means adjustments have been stored in the set.
The tech menu will also always give a much better adjustment of the entire sceen.
Apr 14, 2012 | Sony KP-51HW40 51" Rear Projection...
Need help adjusting the red green and blue lenses of ws 5589 mitsisbshi tv
If you are trying to adjust convergence---go into customer menu and select that option and then advanced---if adjustment there will not cure it circuit needs the chip/s replaced.
If you are talking about the lens---very rare they need adjustment--if picture is 3d looking do not adjust those which are FOCUS. (MANUAL FOCUS OF THE LENS)
Mar 18, 2012 | Televison & Video
Samsung txr3079 adjustment problem: I have a TXR3079 CRT HDTV (chassis type K62B). I replaced the deflection board to stop a whining/noise problem that seemed to be coming from a transformer next to the...
ow voltage i missing one of the diodes in ow circiuts is faulti ,bad,or the resistor between ow transistor and ow diodes is open, bad,or ow transistor is oc
Mar 03, 2017 | Samsung TXR3079 TV
I have a 53 inch hitachi ultravision #53UDX10B Its out of focus and when you press the magic focus button it trys then pops up with the # 4 in the corner is this a convergence problem or what ?
Yes, you have a convergence failure. Usually requires replacement of 2 X STK ICs and any burnt resistors associated with the function that is faulty.
Look at the user menu and compare with images on our Convergence Gallery. Try to adjust in the convergence adjust menu. Identify the functions that do not work and make note. When you replace the ICs, pay special attention to the low ohm resistors for the non-working function. They will be located near the colored plug associated with the non-working function. If red vertical will not adjust, check resistors near the red plug.
There are many posts and websites that offer "new and improved Convergence IC substitutes. My advice is to use the original part numbers and replace any burnt resistors with original values. Many ICs purchased on the Internet are very poor quality and do not work. Many users get substitute replacement ICs and never get their TVs working again.
If you have other electronics repair experience, this job may be done with some chance of success. If you have no experience, there are many secondary problems that can and usually do appear. Determining how to fix the secondary faults and how to correctly align the TV is difficult without prior convergence repair experience.
Some of the common problems encountered are:
1. Poor solder techniques, resulting in damaged PC boards or poor solder connections.
2. Poor quality or wrong parts installed and recognizing this problem.
3. Resistors open or burnt. Some resistors are weakened by the initial faulty IC. Replacing with a "good" IC and starting the TV causes the weakened resistors to burn up. IC may be ok but there are one or more open resistors that measured ok when ICs were being replaced.
4. Wrong ICs used, causing resistors to burn up.
5. Resistors that measure normal and become faulty when heated by current flow.
6. Recognizing that convergence circuit is repaired correctly and alignment is needed.
7. Major alignment in service menu required because data is corrupted by multiple tries of magic focus or manual adjustment while faulty circuit conditions exist.
8. Major alignment required because user adjusted centering rings or physically changed mechanical focus adjustment, then mis-adjusted convergence settings trying to correct mechanical alignment faults.
9. User has not connected plugs and connectors correctly and caused secondary damage or mis-alignment trying to correct secondary issue.
Physically replacing the ICs may appear simple but recognizing if a fault still exists or if correct repair is required causes many attempts at repair to fail. Keep it simple. Replace with good quality original part numbers, measure suspect resistors and adjust only what is necessary.
There are only 3 things to fix, IC failure, resistor failure and user induced secondary faults. Data processor and memory is bulletproof.
easyab
Apr 22, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Colors are not aligned Magic focus ?
The magic focus will stop if there is a bad sensor and or a problem in the convergence circuit.
This set uses two STK-392-110 convergence chips--both along with any of the resistors that protect them need to be replaced and the set adjusted--I have repaired hundreds of these sets----
Confirm model number----and if you go into the customer menu and either red or blue will not move in any or some direction--the chips have to be replaced---LET ME KNOW WHAT YOU FIND AND I CAN GIVE YOU FAIRLY DETAILED INSTRUCTIONS ON WHERE TO GET THE PARTS AND WHAT IS INVOLVED IN THIS REPAIR.
I am here to help people--
REGARDS, SD TECH
Oct 02, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 61swx10B digital rear project
Yes it certainly sounds like you have the old convergence outpuyt IC's that have gone bad in this TV set. If you have the soldering skills, and know how to work on printed circuit boards, you can repolace both of the STK convergence IC's. If you do not, you can get the complete convergence board at http://www.ptscorp.com, and the Hitachi board number is JT22056. Good Luck
Mar 28, 2007 | Hitachi 61SWX10B 61" Rear Projection...
Red is way out of convergence/alignment
If the convergence adjustment is not moving the beam chances are the convergence IC(s) are defective. If you know how to solder and understand TV safety you may be able to fix it. With power disconnected remove the back. You should see two large heat sinks with large ICs (3 by 6 inches) with about 30 leads going through the circuit board. Numbers on the ICs should usually be something like STKxxx-xxx or some variation with x being a number. These ICs control the position of the three beams. If they go bad you can't adjust one or more beams. Replace them both as you don't want to get in there again in 3 months. Cost is not that much. http://www.tritronicsinc.com or http://www.partstore.com should have them at a reasonable price. Before replaceing the ICs look at the circuit board closly for cracked solder joints. Resoldering any bad joints might just solve your problems and avoid replacing the ICs. Good luck and remember safety.
Jul 10, 2006 | Toshiba TP55H60 55" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
