I have a Muratec F-320 Fax Machine. For some reason every day at the same time---10:30 EST, the machine goes into security mode automatically. I can easily turn off the security, but it is very annoying. Any ideas of why and how to turn off this annoying feature? Many thanks in advance.
    Novelist:
  • 170 Answers
There's a few things you can turn off in security, Click Here for the pdf file then go to chapter 3.42 and you should find your answer there... www.BigMoneyCentral.com
Posted on May 13, 2008
What does it mean when my Muratec Fax Machine says DHCP Server Did Not Respond and it will not send or receive documents?
DHCP is the way systems on a network get an address from the network. In a home environment, that's usually done by the router. Unless your fax machine is attempting to send faxes via the internet (rare), that isn't why your machine can't send or receive a fax. If you're talking about sending a fax from your computer, then not having an address is indeed the reason you can't send a fax from your computer.
You will need to see why your router isn't giving the fax machine an ip address. Is it connected to the router? Wireless? Wired?
Jul 08, 2015 | Muratec Office Equipment & Supplies
Muratec F-320 Super G3 we are getting a fax ready Please call Service message
Please Call Service means the machine "thinks" it has detected a fault.
To check do the following..
Press PROGRAM,*, 6
Then press PROGRAM to select Service Call mode, then press ENTER....the error message will be displayed in the display.
Most common error given machine age was "Heater Error".
If this is the case you will need a Serviceman to do repairs to the Fuser Unit.
Oct 25, 2010 | Muratec F320 Plain Paper LED Fax
Muratec F-110 fax machine can send faxs but does not receive, i tried different phone lines, changed configurations changed toner, drum. nothing seems to work thanks, rick
Make sure the machine is in Fax mode and NOT Tel mode. Other thing to try is to pickup handset and listen to see if you hear "Dial-tone" from the line...if you don't then you have probably lost part of the NCU pcb in the machine.
Oct 05, 2010 | Muratec Office Equipment & Supplies
Hello our Muratec F-320 will print faxes with a
lIFT THE BLACK PLASTIC COVER ON TOP OF THE TONER AND DRUM CARTRIDGES. UNDERNEATH THE COVER CLEAN THE ROW OF "EYES" RUNNING FRONT TO BACK. SHOULD FIX IT...PROBABLY HAVE SOME TONER ON THE GLASS EYES.
Jun 24, 2010 | Muratec F-300 Fax
Muratec f320 states: fax ready please call service it continues to send faxes but is not receiving
F-320 "Please call Service".....Press PROGRAM,*,6.....Press PROGRAM to select "Service Call"....error message will now be displayed.
Most common is #02 (Heater Error) which means you have a defective fuser.
Press PROGRAM to show any other error messages.
Press "STOP" TO EXIT.
May 14, 2010 | Muratec F320 Plain Paper LED Fax
Switching to paper tray 2
The machine will only switch to tray 2 IF BOTH TRAYS are set to the same paper size "OR" if the paper sizes are different, the machine will switch to the lower (14") tray when it recieves a document which is 14" long.
You may have the same paper in both trays.... but do you have them both programmed for the same size??? When you select the top and then the bottom tray are they saying they are the same size.????
Apr 17, 2009 | Muratec F320 Plain Paper LED Fax
Need to forward faxes to another fax machine
Fax forwarding is not a feature of the F-320.
Mar 24, 2009 | Muratec F320 Plain Paper LED Fax
Muratec F-300 is not used for faxing, but will not copy either.
Download (FREE) the operators manual from Muratecs web site.
www.muratec.com
Make sure you are in the COPY mode(not FAX.) before trying to make a copy. As the F-300 is a "fax" machine, it will probably be in the fax mode as default.
The downloaded operators manual will help.
Mar 07, 2009 | Muratec F-300 Fax
Muratec F360 Plain Paper Laser.. i need to change the time
What is printed on the top of your received fax's is determined by the sending machine. If the user at the other end does not have name ,date and time programmed into their machine correctly then you will get printed on the top of your received page whatever is in their machine.
Jun 18, 2008 | Muratec F360 Plain Paper Laser Fax
jasbo
jasbo
