Question about Refrigerators
Kenmore model 106.9555913 the water dispenser is running slow. I replaced the filter on the back which I do every 6 months, but it did not make a difference. I have the water turned on at 90-95%, no luck. What should I check first?
ghappliances
  • 126 Answers
SOURCE: kenmore model #106 55522400
YOUR PROBLEM COULD BE WITH YOUR INTERNAL ICE MAKER HEATER ELEMENT OR THE INTERNAL MOTOR OF THE ICE MAKER NOT OPERATING WELL.BEST YOU GET A EXPERT TO ATTEND TO THAT AS IT IS A COMPLICATED COMPONENT TO WORK WITH.GOOD LUCK
Posted on Sep 10, 2008
wecandoit
  • 10 Answers
SOURCE: smelly water from door dispensor
I had the same problem. Drove me crazy and cost me about 5 filters at $50 a pop until I found the solultion. Water in the Sears/LG refrigerator that I have (french door trio) goes through the filter then into a container on the left front door of the refrigerator. That container stores the water so it can get cold and it also equalizes the flows in the system so that when you put your glass under the spigot the flow is steady and the water is cold. Problem is .... this tank can build up with algae/slime/foul tasting stuff. Since it is after the filter, no matter how many times you change the filter it will have no impact on the water in this container. That is why if you use the water spigot a lot, the water seems to get a little better (as the tank water gets diluted) but as soon as you don't use it for several hours or more, back comes the smelly water again. Solution for me was to remove the plastic panel on the inside of the left front door and clean the plastic bottle. It is pretty easy to remove with 2 screws and easy to pull off the hoses. I filled is with a little clorox and water and swished it around for several minutes then drained and rinsed it. Then I filled it again with a little clorox (like an ounce or two max) and put the container back into the fridge. Once in the fridge, I ran fridge water through the front water dispenser for about a gallon or so. This flushed out the chlorine in the plastic container as well as the lines between the container and the spigot. After about a half hour of work, my great tasting water in the fridge is back again. I've checked the taste on this water for several weeks now and no plastic/odor/bad tasting water any more. Hope this helps.
Posted on Mar 12, 2009
Greg20
  • 149 Answers
SOURCE: Whirlpool ED22PE refrigerator in-door water dispenser very slow
remove the saddle clamp that some idiot put on the supply line under your sink and splice in a real "T" with a real cutoff. hopefully the saddle clamp is past your main valve and not before it or you'll have to turn off all your water first.
Posted on Jun 11, 2009
  • 35 Answers
SOURCE: Kenmore Coldspot 106 54689300
DID YOUHOLD THE DISPENSER FOR A LONG TIME AND PURGE AIR ??? ARRE YOU GETTING ICE???
Posted on Jun 18, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
Water dispenser is slow
3 possibilities.
1. Water pressure is low going into the fridge- the way to test this is turn the water off, remove the line from connection in the back of the fridge and put it in a bucket to see the flow. The water should be shooting out with good pressure. If it is not, then you have a plumbing issue, likely at the valve under your sink.
2. Water filter is clogged- If your model has a water filter, it should be changed every 6 months.
3. Bad water valve. The solenoid valve in the fridge, right at the back where the water connects could be going bad and not opening all the way.
May 11, 2012 | Kenmore Refrigerators
I have the Kenmore Elite Trio 795.75546401. There is a sheet of ice under the freezer draw. I cleaned it out and it came back. Have since shut off the ice maker and stopped using the water dispenser. I...
It is definitely the water filter. With the hardness of the water from our county I have to change our filter every 6 months. After replacing the filter be sure that it is seated well. It can leak if it is not fully engaged. Run water through the dispenser until the air is out.
Mar 02, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Want to know when and how to replace water filter on a ge side by side refrig
The water filter status light or indicator, present on some models, will help you know when to change your water filter. The light, or indicator, is located either on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door.
The indicator will be one of two styles.
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red or when water flow to your water dispenser or ice maker noticeably decreases.
If the indicator resembles a stack of bars, the bar height will decrease and the status display will change from "Good" to "Order." This tells you that it is almost time to change the filter. Replace the water filter cartridge when the water filter status display changes to "Replace" or when water flow to your water dispenser or ice maker noticeably decreases.
If a filter status light/indicator is not present, the filter should be changed at least once every 6 months. Your filter may need to be replaced more frequently depending on your usage and water quality.
If the water flow to the water dispenser or ice maker noticeably decreases before 6 months have passed, you may need to replace the water filter cartridge more often. Decreased water flow is a sign that the filter is clogged and needs to be replaced.
If the filter is clogged and you are not able to immediately replace it, remove the filter so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing or low ice production. However, in order to have filtered water, you will need to install a new filter.
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
The filter should be replaced at least every 6 months depending on your water quality and usage.
Step 2
Press the eject button to release the filter from the base grille.
Step 3
Pull the filter straight out.
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing
Hope this helpout in changing the water filter......
Aug 10, 2010 | GE Refrigerators
Slow running water dispenser
the inlet water valve should be replaced but first go to where the water is connected to the pipe and close than open the valve all the way
Aug 09, 2009 | Refrigerators
GE WATER DISPENSER RUNS SLOW AND GIVE WARM WATER
With the refrig , you should have gotten a small bypass piece which fits in place of the inside filter . Install this to see if the filter is good or not . Water faster , replace filter , still slow , possible water valve problem . Also use a connector usually a 1/4 x 1/4 compression fitting , to bypass the outside filter for test purposes only .
Jul 19, 2009 | GE Refrigerators
Water Dispenser
The water does come out slow on these models. I know you said you replaced your filter with a new one and it is still not any faster.
I own a Kenmore Elite #596 73503 201. I have not changed my filter for approximately 18 months and when I timed how long it took to fill a 2 Cup measuring cup (liquid measure) it took: less than 45 seconds. Can you test yours and post back how long it takes with your fridge?
Feb 16, 2009 | Kenmore 73503 Stainless Steel Bottom...
Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
