Question about Broderbund Family Tree Maker 11 (382648) for PC
Installation disk for version 6. for windows 98 does not load , my machine is a compaq presario running widows xp
    Genius:
  • 1,478 Answers
Before you upgrade your existing version of Windows to Windows 98, perform the following steps:
Make sure that your computer is not infected with a virus. To do so, run an antivirus program that has the latest virus signatures and allow the program to remove any viruses that it finds.
  • Disable any programs that run automatically, including antivirus programs, screen savers, and system utilities. After Setup is finished, you can re-enable these programs.
  • Uninstall any utilities or tools that protect or encrypt the master boot record (MBR) or partition table (for example, uninstall the Bootlock utility that is included with Symantec Norton Your Eyes Only). Make sure that you check with the software manufacturer before you reinstall the program to make sure that the version that you want to install is compatible with Windows 98.
  • Back up all critical data on your hard disk. Although it is unlikely that you will encounter a serious problem when you install Windows 98, it is always a good idea to perform a complete system backup before you install a new operating system. When you upgrade your computer's operating system, an error might occur (such as a problem that is the result of incompatible hardware or a power failure) that could temporarily or permanently prevent you from gaining access to the data on your hard disk.
Take care.
Posted on Sep 06, 2010
Compaq SR1650NX HARD DRIVE MESSED UP RECOVERY DISK WON'T WORK REPLACED HARD DRIVE CAN'T GET BIOS TO RECONIZE HARD DRIVE SHOWS UP IN BOOT BUT NOT IN MAIN HP SAID TO INSTALL NEW OS HAD OLD 98SE LOADED WORKED...
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Jul 11, 2010 | HP Compaq Presario SR1650NX...
I have an opportunity to get a free Compaq Presario 1260 with no OS, but I don't know if it's possible to load Windows XP Pro on this type of machine, and I have not tried out my Ubuntu linux disk yet....
My old Toshiba Satellite 490 is even older and has much less processor power and I run XP on it just fine. In fact XP runs faster on it then 98 did.
Known Problems Compaq Presario 1200 laptops are often found with damaged power jacks. Some of these power jacks appear to have been blown in half due to some sort of short; others rip their copper traces off of the motherboard due to stress placed on the power jack. Presario 1200 laptops typically have four tiny copper rings embedded in the motherboard behind the power jack that can be used to reattach a slightly damaged power jack and repair the failing unit.
The LCD Power Inverter cable (which runs through the hinge from the base to the screen), is very susceptible to damage, given the strain of bending when closing the lid. The cable is a 6-strain ribbon variety, and therefore soldering is all but impossible.
Dec 16, 2009 | Compaq Presario 1260 Notebook
Compaq Presario C300 Recoivery Disc 2 corrupt
Hi John.
F11 process is not working and you get a NTLDR missing when you turnon the notebook.
Steps to be performed:
1. Perform hard drive self test from BIOS.
2. If it is passed then use retail version of operating system disk to install XP or try using new recovery disks which nay cost you $15.00.
In your notebook model this issue appears if there is any issue with the hard drive.
Jul 04, 2009 | HP 435768-001 - Compaq Presario C300...
I am not able to install Windows XP on Compaq Presario CQ60-104TU
Recommend removing OLD DOS Operating system First. Then Install Windows XP. XP will NOT upgrade older systems unless it's Windows 98 and Fully Updated. However, can NO Longer do because Microsoft does NOT support any versions other than "2000/ME/XP/Vista".
Jun 09, 2009 | Computers & Internet
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at domnickr@yahoo.com
Mar 21, 2009 | Compaq Presario 1255 Notebook
Need to install driver for sony digital 8 700x
Please mention exact model number of your Sony camera and Windows version in your PC to help you out.
Nov 27, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
I am not able to run setup windows 2000 in my laptop.
HI
Presario was design for windows vista. if I am sure the windows you're installing cannot find the hard disk. I it is not compatible with the machine, look for I higher windows version and I recommend windows XP professional service pack 2 as the lowest you should use.
thanks
Nov 24, 2008 | Compaq Presario 700 470024-192 Notebook
Need Windows XP Driver's For My Laptop
There are several versions of the Presario C700. Pls try here and select one appropriate ti what you have. Thereafter, clicking on the exact model number would open a new page with drivers for several Operating System, pls select Windows XP. If there are no specific drivers, download and install the HP Software Update.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 17, 2008 | Compaq Presario 700 470024-192 Notebook
Installing widows XP
first, have a WIN XP startup disk...created by (in windows)  inserting floppy and right clicking choosing format and select option "create MSDOS startup disk"
first backup all personal files...then restart and bypass to DOS screen at startup...try using F8 key just after BIOS screen...then select startup to DOS prompt only...then run (from the floppy disc) format c:
now you should have a nearly bare hard drive. repeat above steps and this time choose "startup using CDROM drivers"...then insert CDROM and redirect to that drive letter (d drive?) and run setup.exe.
Oct 30, 2007 | Compaq Presario C552US Notebook PC
Broderbund Family Tree Maker 11 (382648) for PC Logo
50 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
