KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
After I registered my Kodak EasyShare camera, I could download updates for the Picture easy software for free with Kodak.
My guess is they still have the newest software for all users. (I'm now using Nikon, so I did not update from Kodak for a long time)
Do you mean the lock on the memory card , take it out of the camera and youll see a tiny plastic switch , move it to unlock and that should do the trick , best of luck
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
On the newer versions of Easyshare 7.0 up to 8.0 there is an option to CD/DVD Burn
Just simply insert the CD on your Computer and Put the pictures you wanna burn on the Picture Tray<right side pane on easyshare> Click on the icon for CD Burn
If you have a lower version of Easyshare
visit www.kodak.com/go/easysharesw you can download the latest version from there but before downloading it make sure you remove your current version so it will not conflict with each other
1. Install EasyShare software (free download at www.kodak.com/go/sw)
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Hi , if you do not have important in your camera jus open camera tools select format all picture will gone even lock picture will finish. hoping you will satisfied the tips.
