Question about Cycling
Installation instructions for Bell Riderz training wheels
Show me to install training wheels
Posted on Aug 19, 2011
I exchangedBell Kidz street trainerz traing wheels pink. Toysrus can not believe how this was made. Here is the issue: The piece that is supposed to go UNDER the hollowed out brace on the inside, does not fit there. It fits on top of the brace with the **** that are supposed to fit into the **** in the bike structure to stablize it juts out for a leg to get cut on. installation picture,was just emailed to me, shows it under the brace jutting out- in fact, it does not fit under it, it only fits on top of it and the metal legs that should stabize it are on the wrong side. l So not only is it made *** end backwards it also does not fit in the correct spot . a bike person and Toys R us and the manager Mary witnessed and agrees with this. I believe this needs to be recalled, not sold in any stores and more safety and quality product control and testing done at the manufacturer.
Posted on Jul 20, 2012
2 Suggested Answers
SOURCE: instructions for bell riderz training
Installing is easy if you take a look at the inside of the package! There are two nuts and a few washers on the screw that is used to hold the actual wheel. Make sure that you do not overtighten the first nut otherwise the wheel will not rotate freely. They appear sturdy enough. Only time will tell how much they will last!
Here is how to do the install:
1) Place the axle bolt through the wheel.
2) Thread one of the nuts on the axle bolt until it stops (use a flat washer here).
3) Put the axle through the frame. If there is a round washer, place it over the axle bolt next.
4) If there is a lockwasher, place it over the axle bolt.
5) Thread the other nut onto the axle bolt, then while holding the first nut, tighten the second one.
6) Install the assembly onto the bicycle.
Posted on Dec 17, 2012
How do I clean the tracks & wheels to stop the short circuit?
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating minutes wondering why their train wouldn't move.
Nov 13, 2013 | Lionel Trains Holiday Express G Gauge...
I bought bell trianing wheels and i have no idea how to attach them to the bike they did not come with any instructions
Unbolt the bolts on the rear wheel (pay attention to approximately the amount of torque to remove the bolts). Slide on the legs with a hole on one end and a curved end to fit the frame. Slide on the training wheels so the training wheel sticks out and is at an appropriate height for the bike. replace bolts with approximately the same torque as before. Also make sure the tire is seated as far back in the frame as possible to keep tension on the chain.
Jul 14, 2011 | Cycling
I am trying to install Schwinn training wheels and the instructions are not very good.
The best training wheels is the parent holding onto the seat while the youngster learns and develops balance.
Jun 30, 2011 | Cycling
Can you give me step by step instructions for installing the training wheels by bell
Somone else had a good answer:
http://answers.yahoo.com/question/index?qid=20100311194216AA1phl1
"Best Answer - Chosen by Voters
You really shouldn't be doing this unless you are able to work this out yourself, but in the interest of safety, here's how to do it:
Each stabilizer "side" has a wheel, an axle bolt, 2 nuts, and the frame. This means that in total you should have 2 wheels, 2 axle bolts, 4 nuts, and 2 frames. There may be some star washers as well.
2) Thread one of the nuts on the axle bolt until it stops.
Although you may be the handy type, I strongly suggest you take everything to a bike shop for correct assembly. Isn't your child worth it? Source(s): 30 years in the industry"
Jan 16, 2011 | Cycling
Instructions for bell riderz training wheels
Dec 25, 2010 | Cycling
Bell brand bicycle training wheels
hello there:
the training wheels are a simple procedure you will need to take the nuts off the back wheel and place the steel spacer and put over the axle then place the training wheel over the spacer and put the nut on making sure the the training wheels are not too low or too high.... best of luck to you hope the information is helpful
May 29, 2010 | Cycling
Install training wheels
when installing the training wheels, check to see if it is put together in this order ....flat washer, training wheel, flat washer, lock washer, nut. I hope this helps. If you are missing any of these you can find them at any auto parts store, Wal-mart, or hardware store such as Lowe's or Home Depot. (Be sure to take the traing wheel and nut to make sure you have the right size)
Dec 27, 2009 | Huffy Disney Princess 16 in. Girls Bicycle
What is the shorter metal piece of training wheel
http://www.ehow.com/video_4974885_put-training-wheels-bike.html This might help.
Aug 19, 2009 | Cycling
Cycling Logo
3,382 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
