Question about Dryers
We have an older Kenmore Ultra Fabric care 80 series dryer that has started to not turn off a week ago. My husband unplugged it two nights ago then when we went to plug it back in, it won't start. It's getting power (it sparked when he was testing a wire in the back) - is it the thermo fuse, we need to clean the blocked vent tube or something else. Please advise. Thanks! Steph
  • 1 more comment
  • gladys2626 Sep 06, 2010
    Rylee,
    One thing to add,would that stop the dryer from spinning too? I believe my husband has replaced that before - is that normal to have to replace that twice?
    Thank you!
    Steph
  • gladys2626 Sep 09, 2010
    Hi Rylee-
    I have an update and I wanted to make sure you have all the info (recapped below), see if you still think it's the belt, thermo fuse or maybe now, timer??
    A week ago the dryer wouldn't stop spinning and it was heating. The fact that it was acting oddly made my husband unplug it. When he plugged it back in, it would not turn on. At that point, we checked the fuses, house fuses (which were fine), and we knew the dryer was getting power because of the sparks (I mentioned earlier).
    My husband took off the back cover of the control panel and discovered 3 wires with some burn damage/melting. The red wire, the black wire at (*9 o'clock) and what he believes was a small ground wire. He thinks that the failure of the dryer to stop running coupled with the burn evidence is pretty strong evidence it's the timer. He cut off the burn parts of the wire, replaced the female clips and reattached the wires to timer but no luck.
    If the dryer was heating to begin with, but there was an obvious problem with it shutting off? Is that thermo fuse? It now seems it's a timer issue. Although, he hasn't checked, the same logic suggests it is not a belt issue either. Timers are pretty expensive, can you think of anything else this may be - is there another part that may have failed causing the surge to the timer wires.
    Thanks again for your advise.
    Steph
    Yes very!! Thank you Rylee.
    Brigadier General:
  • 8,619 Answers
Hi Steph,
Thanks for using FixYa. Yes you are right, it seems to be an issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. You can check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 06, 2010
  • Rylee Smith
    Rylee Smith Sep 06, 2010
    If it wont spin at all then it is the belt that has gone bad and should be replaced.
  • Rylee Smith
    Rylee Smith Sep 09, 2010
    Thanks for your reply Steph, from what all you have described it seems to be the Thermal fuse that has gone bad, the belt appears to be working fine as the dryer was spinning. To start with you can test the continuity of the Thermal fuse, check between its two pins, no continuity means bad fuse and to check the timer you can also test it, replace the part that has gone bad. You can also check this repair manual that might help you for repairs. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Kenmore ultra fabric care II 80 series. Washer won't start on 10. But it will start on 4, every position past that and run thru the rest of the cycles fine
i WOULD SUSPECT THE TIMER CONTACT POINTS AT 10 ARE BURNT OR SEIZED YOU CAN TAKE APART AND CLEAN THE CONTACT POINTS IF U KNOW WHAT UR DOING.
Dec 19, 2016 | Kenmore Washing Machines
I have a kenmore ultra fabric care heavy duty 90 series soft heat i will not come on hum not nothing
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 28, 2011 | Dryers
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
No heat coming out
It will either be a blown element or possibly a fan belt broken on the back under the plastic cover.Hope this helps Cheers.
Jul 30, 2009 | Dryers
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
only thing i can think of without being there and able to test parts is your door catch could be faulty
Aug 10, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
