Question about Boating
The starter will not engage to the flywheel on a 1990 Johnson 25 HP Outboard. The solenoid works but centrifical mechanism does not.
    Novelist:
  • 184 Answers
You may just have a weak battery, so get the one from your truck and see if that helps. If not get your jumpers and attach one to the negative and force it to have a new ground. Still nothing? take a pair of pliers and use the handles to arc across both big lugs on the starter solenoid. This may cause sparks --so no fuel nearby!! If that isn't doing it, you need a new starter, BUT try tapping the starter body with a big screwdriver handle first.
Sometimes the brushes are just stuck.
Posted on Aug 01, 2012
    Problem Solver:
  • 7 Answers
Try spraying some CRC Light lubricant on the spiral where the pinion gear slides up and down. Can you turn the gear so it will move up to the flywheel? If it turns and stays at the bottom, you will need a new pinion gear! Does the starter motor spin?
Posted on Sep 07, 2010
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
My 1977 85 hp Johnson motor will trim up but not down. I traced the wires from the trim switch to the solenoid and all are hot. I replaced the solenoid but it still will not work. I can cross out t
2 solinoides , one for up and one for down !!!! test trim switch then try swopping up solinoide to the down and problem could be solved !? check wires !
Jul 31, 2014 | Sierra Outboard Starter for...
Evinrude motor problems
The stater gear is thrown up by the quick spinning of the starter motor. It is on "ramps" that move it up. They can get corroded or gummed up. It should have a very light or dry lubricant on them.
Also if the motor is worn it may not accelerate with enough "snap"
If the battery is weak or the connections are corroded, you can get the same result. Hope this helps.
Jul 27, 2014 | Johnson Evinrude Starter-Outboard -92...
50hp johnson outboard
Look on thin red wire that leads from starter solenoid,holder is normally situated on top of cylinder head
Dec 15, 2013 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
Where is the starter located on 1985 Honda Civic?
The starter is located on the firewall side of the engine block, adjacent to the flywheel or torque converter housing. Early models, use a direct drive type starter, while the later models use a gear reduction starter. Otherwise, the two units are similar in operation and service. Both starters are 4-pole, series wound, DC units to which an outboard solenoid is mounted. When the ignition switch is turned to the start position, the solenoid armature is drawn in, engaging the starter pinion with the flywheel. When the starter pinion and flywheel are fully engaged, the solenoid armature closes the main contacts for the starter, causing the starter to crank the engine. When the engine starts, the increased speed of the flywheel causes the gear to overrun the starter clutch and rotor. The gear continues in full mesh until the ignition is switched from the start to the on position, interrupting the starter current. The shift lever spring then returns the gear to its neutral position.
Begin the starter removal by first disconnecting the wires leading to it
Hope helps (remember rated this).
Jul 14, 2010 | 1985 Honda Civic
1990 Volvo 249 DL Stater issue !
pull starter and clean, check stater solenoid, check all electrical connections
Sep 13, 2009 | 1990 Volvo 240
Looking for a starter solenoid wiring diagram
save yourself some money and go get a lawn mower solenoid and find a way to mount it yourself. I have done a johnson outboard and a tigershark jet ski this way with no problems.
Jun 18, 2009 | Boating
Boating Logo
250 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
