Lexmark X75 All-In-One InkJet Printer Logo
Posted on Sep 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have windows 7 need the drivers compatible with my software. pleaseeeeeeeeee!!!!
Anonymous
Level 2:
  • Expert 304 Answers
  • Posted on Dec 06, 2010
Anonymous
Expert
Level 2:
Answers
304
Questions
0
Helped
112950
Points
794
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) I have windows 7 need the drivers compatible with - julyallan01_52.jpg
Which artlink is compatible window7, aurora 430 and embroidery unit.Artlink6 is working but doesn't allow me to write to machine.Editor lite v4 doesn't pick up dongle.Nothing wrong with USBports
This sounds more like a driver issue than a software problem. The ArtLink 6 software CD that came with the Aurora 430 had drivers for XP and Windows Vista. However, these drivers may have only been for the 32-bit OS. Windows 7 is the first version of the OS to have had a large number of 64-bit installations.
The latest drivers for the Aurora 430 is available here: https://berninaofamerica.zendesk.com/hc/en-us/articles/200183069-Aurora-Driver-Windows-Vista-7-and-8- . You will need to install two drivers; follow the directions on the site. Make sure that the USB cable is good and that you aren't using a USB hub.
If you have installed the drivers and the ArtLink 6 software still isn't working, ArtLink 7 is fully compatible with Windows 7 and the Aurora sewing machines. The only download site for this software that I've found is https://www.bernina.com/en-CA/Products-CA/BERNINA-products/Software-Designs/BERNINA-Embroidery-software/Advanced-Embroidery-Software/ArtLink-Seven . ArtLink 8 is also Windows 7 compatible. However, I haven't found any documentation on the supported sewing machines.
The driver issue also applies to the dongle. Try this site: https://www.bernina.com/he-IL/Support-IL/Software-he/Embroidery-Software/Dongle-Driver . However, since you have the Editor Lite v4, this dongle may not be supported under Windows 7. The dongle driver is not updated regularly. For some information about the software limitations, see https://www.bernina.com/he-IL/Support-IL/FAQ-he/Software-he/Can-I-update-my-BERNINA-embroidery-software-Editor .
I hope this helps.
(There is a patch for the v5 software to run properly under Windows 7. There isn't one for the Editor Lite v4 to the best of my knowledge.)
1helpful
3answers
Scanner doesnt have a driver for windows 7
This may help. Depending on your version of windows 7 you may be able to run Windows XP as a virtual machine and still user your scanner under XP Mode. You will have to install the XP driver for your scanner on the XP virtual machine running on your Windows 7 computer.
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software.
HERE is the direct link to instructions on downloading and using XP Mode on Windows 7
1helpful
2answers
I have windows vista 64bit which is given me a lot of software compatibility problems.I now want to install windows 7 32bit or 64bit.I have the software i need the drivers how can i download them.
Hi ,
If you still have Vista on your machine , insert W 7 install disc and select " upgrade " and you should'nt worry about drivers .
If you already have installed W 7 , let W 7 search the missing drivers ( go to the device manager and select the yellow triangles ) .
If some drivers are still missing , you will need to search manually on the manufacturre's site .
Good luck !
Regards ,
Thanks for visiting Fix Ya .
I have lost the instalation disc for my hp scanjet 2200c scanner what can i do now also will it install on windows 7
Its difficult to say if the driver software will work on Windows 7, although Windows 7 is very forgiving when it comes to older software. Here is the link to the driver and software page for your scanner:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=uk&prodNameId=28416&prodTypeId=15179&prodSeriesId=28415&swLang=8&taskId=135&swEnvOID=228
Try the Windows XP driver and remember that if you have any compatibility issues, you can always right click on the driver setup file and choose the compatibility wizzard: In this case, choose the Windows XP compatibility option.
Please let me know if you need any further assistance.
Best wishes,
Graemevm
1helpful
I have a EPSON stylus color 740. Unable to find software driver to download in my laptop window 7
Sorry to say that your printer is not having any compatible driver for windows 7 . You need to contact epson for getting any compatible driver so that it works with windows 7.
Hope this helps.
5helpful
I want usb drivers for samsung s3500 for windows 7
Samsung only lists Win 2000/XP/2003/Vista software for the S3500. Click here: http://bit.ly/aDaFW5
After clicking the link, you'll need to click on, 'Software' (next to the work 'Manual') to locate the available software downloads.
Note:
1) You may be able to download the software and then run it in 'Compatibility Mode' in Windows 7, or
2) When you install the software, Windows 7 may automatically run the drivers in compatibility mode.
1helpful
Updated to windows 7. labtec web cam not
HI,
There are currently no windows 7 drivers/softwares available for windows 7 from Labtec.
The only solution is to contact the Labtec support team and ask them to email you the windows 7 compatible software for your camera.
Contact Details:
44-203-024-81-61
Thank You for using fixya.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
