Question about Krups Caffe Bistro 867 Espresso & Coffee Maker
Switched it on to heat, waited for yellow light to extinguish, red light was on, when trying to steam milk red light got really dim and nothing would happen. Switched machine off and waited a couple of hours, when trying to turn on (toggle swithc), neither the yellow or red light will come on, totally dead
  • hoetjen Sep 06, 2010
    I can do the repair you dexcribe, but need instructions on how to dissamble the expresso maker in order to gain access to the PC board.
    Thanks henning
    Genius:
  • 1,340 Answers
With a dimming light like you described,something in the power circuit slowly fried.You probably should have smelled burning or heat yet also may have not.Something burned up in the power circuit.If you want to repair,shipping will probably cost at least $10.Parts by a repair center have a minimum markup of 20% and labor can range from $40-$60/hour.I am telling you this so you can determine cost of repair versus replacing.
Good luck! Greg
Posted on Sep 07, 2010
  • 22,156 Answers
On the circuit board is a relay that supplies the power by switching it on and off ,which is controlled by the thermostat ,now these relays often get burnt contacts inside and they need a new relay which has to be soldered in ,this is not really a home type repair that i would recomend but take it to a local repairman as they have to be stripped and the relay soldered in onto the circuit board which is easy with the right tools .
Posted on Sep 06, 2010
Low steam pressure
descale the heating elements with vinnegar.
Mar 20, 2014 | Rancilio Silvia Espresso Machine
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
The milk steamer is not frothing. I have tried cleaning and descaling
If it does not produce steam when you switch to steam mode and wait for it to heat up, the steam thermostat needs to be replaced.
Mar 03, 2011 | Krups Espresso Novo 2100
Sylvia still makes great milk for steam but on Saturday it stopped producing hot water for expresso. What do I do? I live in North Tas
Hi
. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Nov 15, 2009 | Rancilio Silvia Espresso Machine
Miele CVA615
miele's parts are available direct through them only
Sep 22, 2009 | Miele CVA615 Espresso Machine
Can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Feb 22, 2009 | Cuisinart EM-200 Espresso Machine
Losing steam
Try to descale the machine to see if will be better.
Aug 13, 2008 | Gaggia Classic Espresso Machine
Dualit 889 espresso coffee maker problem
To pull a shot
1) Turn machine on (innermost right switch)
2) Red light goes on (power on)
3) Yellow light goes on (thermablock heater)
4) Wait for yellow light to go off
5) Detach handle (pull to left)
6) Clean handle, remove crema sieve, clean with soap & water
7) Put crema sieve in handle (you should have a choice of two)
8) Put espresso ground coffee in with brown handle
9) Tamp coffee down FIRMLY with handle
10) Place handle back into machine (push to right)
11) Ensure flip switch on leftmost side is at top position
12) Flip down rightmost switch to infuse coffee into handle
13) Wait 18 - 24 seconds
14) Flip up rightmost switch to turn off infusion
15) Put milk into container (about 200ml in a 600ml container)
16) Flip down rightmost switch to bottom position = steam
17) Keeping tip about 5mm from top of milk, foam to ~400ml
18) Place sugar in coffee, if desired
19) Pour milk in coffee
LATTE
YUM
May 06, 2008 | Dualit Espresso 889 Espresso & Coffee...
Starbucks Athena
I have had this machine for four years now, and it is FAB!!! it does have an extra step to it- after you put in coffee and add water to the reservoir, you DO need to prime the pump. So here's what you have to do:
-Fill the reservoir with MORE water then you think you will need, fill the coffee filter with the standard amount of finely ground bean.
-Turn the machine to "on," making sure the "steam" switch and valve (knob) are off.
-Wait till the green "ready" light comes on, then put an empty cup under the steam wand and turn the valve on (the steam switch is still in the off position). Hot water will come out of the steam wand, allow it to flow until the "ready" light blinks off. Discard this.
-close the steam valve, stopping the flow of water.
-turn the "steam" switch into the on position, wait for ready light to come on again.
-put your milk container under the steam wand and froth to your heart's content (this machine makes GREAT frothed milk and you should use a large enough milk container to allow for that! *smile*)
-when you have finished with the frothing, close the valve and flick the "steam" switch back into the off position. You are now ready to make your espresso.
-push either of the two buttons, ie one or two cups, and the espresso will start to flow. There is a way to set the length of time for each of the two buttons, but I have had mine set perfectly for so long i don't know how to do it any more. Sorry!
This has been the best machine I've ever used, and has lasted me for years. I heartily recommend it!
Jan 02, 2008 | Estro Barista Athena
Krups Caffe Bistro 867 Espresso & Coffee Maker Logo
124 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
