Question about Milwaukee Tool Case Heat Gun
Case 5130 indicators not working fuses ok warning lights ok ?
Fuses ok,light in dash tested and works. But check engine light does not come on when you turn on the ignition. What else should I check? This is a ford ranger XLT 4x4 4.0L V6-245cid engine (pushrod)
The instrument cluster (10849) carries out a display proveout to verify that all warning/indicator lamps and monitored systems are functioning correctly. When the ignition switch (11572) is in the ON position with the engine (6007) off, the following indicators will illuminate:
  • CHECK ENGINE/malfunction indicator lamp (MIL).
  • CHECK GAGE warning indicator.
  • Charge system warning indicator.
  • Anti-lock brake warning indicator (ABS).
  • Safety belt warning indicator (60second proveout).
  • Air bag indicator.
  • An indicator is inoperative - CHECK ENGINE/malfunction indicator lamp (MIL)
  • Bulb.
  • Circuitry.
  • Instrument cluster printed circuit.
  • Powertrain control module (PCM) (12A650).
  • GO to Pinpoint Test N .
Feb 15, 2016 | Cars & Trucks
FFA74 HIGH TEMP WARNING LIGHT
That indicates that your system is low on Freon or there is a leak somewhere in you sealed system.
samedayappliancerepair.ca
Jul 06, 2017 | Refrigerators
Opel Corsa Utitilty 1.4i right indicators don't work even after I changed the globes
If the lamps and bulbs are ok I would initially suspect the hazard warning light switch, then the indicator switch, the multiway connectors and then the wiring.
There is generally only one fuse for the indicators and as one side is working it can be assumed power is reaching the indicator circuit.
Feb 01, 2012 | Cars & Trucks
I have a 2004 Jeep Cherokee Laredo. An indicator (with a symbol of what looks like a radiator) below the low fuel indicator (bottom left had side of the dashboard) lights up and remains on. I have checked...
2005 Instrument cluster layout
1. Speedometer
2. Brake warning light
3. Turn signal indicator light
4. High beam indicator light
5. Malfunction Indicator Light (MIL)
6. Airbag warning light
7. Anti-Lock brake warning light
8. Tachometer
9. Security alarm indicator light
10. Oil pressure warning light
11. Electronic Stability Program (ESP)/
Traction Control System (TCS) indicator light
12. Tire Pressure Monitor warning light (base)
13. Temperature gauge
14. Electronic Vehicle Information Display
15. Tow/Haul indicator light
16. 4WD Low mode indicator light
17. Seat belt reminder light
18. Cruise control indicator light
19. Odometer/Trip Odometer
20. Transmission gear indicator
21. Fuel gauge
22. Electronic Throttle warning light (5.7 Hemi)
23. Front fog light indicator light
24. Voltage warning light
Jun 05, 2011 | 2004 Jeep Grand Cherokee
Does the 1992 dodge dakota automatic trans have a fuse to overdrive button
The fuse number is
#16 - 5 Amp (Tan)
Gauges & Indicator Lights: Low Oil Light, Low Washer Light, Service Reminder Light, Transmission Oil Light, Brake Warning Light, Anti-Lock Brake Warning Light, Fuel Pacer Light, 4WD Indicator Light, Malfunction Indicator Light, Warning Buzzer, Overdrive Switch (1992-93); Transmission Oil Temperature Lamp, 4WD Lamp, Overdrive Module Seat Belt Warning Buzzer
(1994-95).
Jan 25, 2010 | 1992 Dodge Dakota
Left rear brake light stopped working but bulb and fuses are OK.
These are Dual Function Bulbs. They control the Parking Lights and the Brake Lights. This Bulb is Burnt out on the Brake Coil inside the Bulb. I have actually seen Bulbs that were Bad But you could not Tell by jast looking at them. It should be fine with a New Bulb. Please Rate My Response! Thanks!
Feb 05, 2009 | 1999 Ford Expedition
My indicators and hazard warning lights have both suddenly stopped working have checked all fuses all seem ok
I think there is an issue with turn signal switch, test the leads at the switch that are supposed to have power, if they are ok replace the switch. An inexpensive test light will do nicely for these checks.
Aug 21, 2008 | Alfa Romeo 156 Cars & Trucks
Indicator warning light
Hi fisics,
I believe that corroded terminals in the light cluster can cause the warning light to come on.
But I once read that there is something else, entirely unrelated to the indicators themselves, that can cause this warning. Possibly another system powered through the same fuse or relay...When I remember what it is I will get back to you. It's pretty late here in Scotland. :-)
Cheers, D.
Jun 30, 2008 | 2004 Volkswagen Golf
Milwaukee Tool Case Heat Gun Logo
82 people viewed this question
Top Milwaukee Tool Air Tools & Compressors Experts
John Trevino
Geert Deschamps
Are you a Milwaukee Tool Air Tool and Compressor Expert? Answer questions, earn points and help others
