Question about HP DesignJet 1050c InkJet Printer
SYSTEM ERROR 09A008 007A07A3- WHAT DOES THIS MEAN?!?!?!?
  • HP Expert
  • 141 Answers
Either network card or hard drive.
remove the network card and turn the machine on.
if the error persists then replace the hard drive.
If the error does not come back then replace the network card.
Good Luck!
Posted on Sep 09, 2008
Where did the hard drive
Posted on Oct 31, 2012
What is error 0xc19a0003 mean for the HP Officejet 4620
ink system failure - error 0xc19a0003 means ink system failure error usually occur if you have issues with your ink cartridge or printheads. Have you try replacing either of the two?
May 12, 2014 | HP Officejet 4620 e-All-in-One Printer,...
My xbox has 3 flashing red lights on front. What does this mean
It means your system has the dreaded RROD Or Red Ring Of Death,
If you turn the system on and hold the sync button and then hit the eject button, You can find its code you will have to do it 4 times, 1 light means 1 2 lights means 2 3 Means 3 and 4 lights means 0.
You can usually get a code like 0020 0102 and so on, below is a link that will tell you what each error code means,
also look at the back of your system locate the manufacture date, If it's within 3 years of that date don't open the system call microsoft and have them fix it for free.
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Sep 10, 2010 | Microsoft Xbox 360 Console
Error code 400
If it is system error code.
System error code 400 means "The thread is already in background processing mode." This error code may also display as "ERROR_THREAD_MODE_ALREADY_BACKGROUND" or as the value 0x190.
Try this,
Clean your system using any commercial or free system utilities like CCleaner(free), and cleanup the system registry too.
Jul 08, 2010 | Microsoft Windows XP Home Edition
What is this error mean that i get during boot up? 312.198 Eth0:(185488) System Error Occurred (0) 312.199 Eth0:(185489) System Error Occurred (0) 312.200 Eth0:(185490) System Error Occurred...
I think this is related to to the NIC (Ethernet port).
Go into the BIOS and set it to default settings, see if that resolves the problem.
Let me know how you get on.
Regards.
Jun 30, 2010 | MSI P4MAM2-V Motherboard
I use a Canon ImageCLASS MF4350d Laser All-in-One (2711B001AA) Printer. When i want to photo copy, it shows system error -E225. What does that mean?
I think that error code means a problem with the scanner/lamp. Any type of Exxx code means the machine needs (repair) service. This is a fairly new product and should still be in warranty, so I recommend you contact your regional Canon service agency.
Nov 11, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
Have a 2004 GTO with the following error: Fuel Guage Error - Contact Dealer Service Error - Contact Dealer Air Bag Fault - Contact Dealer Any idea how to fix this?
If these are false readings (which I doubt) you can try resetting the system to restore all factory default settings. You need to have the system set in customisation mode to do this.
Check your vehicle handbook which explains the steps to do this.
Once reset drive the car and check the warnings.. If they remain (and they probably will) you will need to take the car to the dealer to diagnose and rectify the problem.
Your handbook explains what each of the warnings means and the air bag fault warning should not be ignored. "Service error" means there is a fault with the instrument panel and Fuel Gauge Error means there is a fault with the fuel level measurement system
Oct 20, 2009 | 2004 Pontiac GTO
Error codes 0442 and 0445
Hi..my name is Keith..and the error code P0442 means...Evaporative emission control system,small leak detected ...and error code P0445 means....Evaporative emission control system,short in purge control valve circuit..i hope this has helped
Jul 04, 2009 | 2002 Dodge Dakota Club Cab
What is error 00173, 00192, and 00163
Error 192 means a fan error, to test this measure the voltage of the backup battery. If the
voltage is not correct, replace the backup battery. Check the fan and the system board.
Error 163 means the time and date is not set, to set the time and date hit F1 when you see the IBM logo and set the time and date.
Error 173 means the configuration data is lost, to sort that select OK in the error screen and set the time and date.
In most case its the CMOS battery that's run low and need to be changed for a new one, so for the time being you will have to keep setting the time and date and it will boot to windows.
Good luck
Jun 15, 2009 | IBM Thinkpad 600 System Board Motherboard
System error prob.
The "File System Error" message is bad - it means that, rather than deleting just music files, you have accidentally deleted a key system file required for the Go Gear to operate properly. If you are still under warranty, call Philips and get a replacement GoGear, because they do not provide replacement files.
-Tha Mp3 Doctor
Feb 16, 2009 | Philips Sport Personal CD/MP3 Player
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
HP DesignJet 1050c InkJet Printer Logo
854 people viewed this question
Seeker5211
Seeker5211
