Question about Kenmore Elite 45986 Front Load Washer
F30 code? Makes a weird noise and drains the soap from dispenser but no water is added and won't spin.
  • 15,935 Answers
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 07, 2010
WHAT IS F30 CODE
whirlpool duet front loading washer use a motor on top the dispenser assembly to switch the water in the dispenser between washing out the soap,bleach,and fabic softener compartments of the dispenser. Take a shop vac to the dispenser area. I think it is stopped up. It can have something in pump too
Sep 05, 2017 | Washing Machines
My flow indicator won"t spin but water dispenses
Check the belt on the soap pump. Water may be dispensing but soap is not mixing with it when the indicator is not spinning.
Feb 11, 2015 | bissell"" pro heat 2x select upright deep...
Kenmore Elite 5t shows an F30 code, water fill solenoid is making a noise like its not opening
This is a dispenser motor issue. If you pull the unit out and remove the 3 screws coming into the back of the top panel, you can remove the top panel to access the top of the dispenser. There is a motor that turns a plastic lever on the dispenser. you might be able to manually help the arm move to get past the error code, but ultimately you will need to replace the dispenser motor. Here is the part to order.
Dec 03, 2012 | Kenmore Elite HE5t Washer
My whirlpool sport washer is flashing an F30 and making a terrible noise in the origin of the soap dispenser area and appears unalble to pump water into the machine for the cycle to begin
The F30 code refers to a failure of the dispenser motor. The clicking you were hearing was probably the dispenser motor switch going on and off trying to activate the dispenser motor.
this is an easy and relatively inexpensive repair that you can do yourself.
Jun 22, 2011 | Washing Machines
Water coming out of soap drawer
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) .Water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning.
Black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases you have to replace the dispenser.
Feb 05, 2010 | Hotpoint First Edition WMA22 Front Load...
Turns on makes weird humming noise
The noise is most likely your drain pump trying to clear water from the sump area. If you remove the bottom screws holding the lower access panel in place, look for the drain pump and a block rubber hose connected to it. I suspect there is something preventing the pump from draining all the water. Remove the clamp holding the hose to the pump (have towels handy as there will be water) and clean out the sump, then put it back together and give the washer another try.
Mar 08, 2009 | Frigidaire GLTF2940ES Front Load Washer
Dishes are not getting clean
If the spray arms are not being blocked by a dish or a piece of flatware then you may have a valve that is not letting enough water through to get the job done. water condition may clog the valve and energy efficiency mandates using less water so some valves are made with smaller holes today. A little knowledge that may be helpful when seeking a solution to your problem. Good luck.
Dec 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Code F30
before calling for service ck fill hose screens to be sure they are clean on some models the f30 code indicated possible problem with dispenser linkage you can ck that by removing 3 screws along back edge of top slide top back and lift off linkage is on left at dispenser if this looks ok sears servoce # 18004694663 or ae 18009059505
Aug 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
385 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
