Question about Electrolux Vacuums
How do you install the air filter in a Renaissance Electrolux cannister? I found an oversized air filter in the my last bag of R type filters. Do I need the air filters and if so, where do they go? I have had this vacuum for 10 years and never noticed the filters existed! do you cut it to fit? Does it go in the bottom of the filter compartment? Which side goes down vs faces the bag? Is there a special compartment that I don't know about besides where the bags go?????
  • 694 Answers
It goes beneath the accessories holder on top of the machine.
You can download a manual for your machine at the below site:
http://www.aerusvacuums.com/support/manuals/index.cfm
Posted on Sep 07, 2010
How do I change the air filter
the top of the vacuum where the tools go comes off,the filter goes underneath..Chris
Jun 25, 2014 | Electrolux Guardian Bagged Canister Vacuum
Whwre do u put the pre-motor filter on electronic renaissance vacuum
The filter goes under the tool caddy. Press the latch just behid the bag door. Prees the two tabs toward each other to release the catch of the tool holder and lift out. Remove filter and replace.
Slip back of tool caddy in first, then press front down to latch it. Close the top and you're done.
You cann find a manual using the following link. It's the next to last one under Older Models.
Mar 02, 2011 | Electrolux UltraLux 2000 Bagged Canister...
How do you replace the 'after filter' in the electrolux guardian?
1. Press latch and open the door that covers the tools.
2. Squeeze clips at front of tool tray, lift and remove.
3. Remove filter.
4 Replace filter.
5. Replace tool tray and close door..
Instructions can be found in the Renaissance manual, which you can download from the following site. Go to "older models", find Renaissance and click on it, then click "download". Instructions are on page 9. The Renaissance is basically the same model as the Guardian.
Nov 28, 2010 | Electrolux Guardian Bagged Canister Vacuum
LUX RENAISSANCE WONT TURN ON. HOSE CONTROL BAG LIGHT IS ON
Could be the board in the handle but I found that a lot of the times the contacts where the handle meets the hose just need to be cleaned. It could also be a clogged hose but I'd say it's one of the other two.
Dec 04, 2009 | Electrolux Vacuums
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
Have the cannister 6500 SP just changed all filters but when I start the vaccum it shuts itself back off and the full bag indicator light comes on?
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
Jun 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Pops open when bag still almost empty
try cleaning the filters if they are blocked then suction is lost and would appear like bag was full. hope this helps
May 20, 2009 | Vacuums
Electrolux renaissance bag is light and vacuum stops and the change bag light comes on
Mine is doing the same thing, well it was. I sat it upright and it seems to be working fine... there is no blockage in the hose, the bag is clean... only thing I can't change is the filter. Maybe that is the problem, it doesn't seem really dirty though. I'm thinking perhaps the unit was too hot, hence having to be turned up right... makes it a little harder to move around but it is running at that is all I care. Hope this helps
Aug 29, 2008 | Electrolux Vacuums
RENAISSANCE HOSE/VAC
THE RENAISSANCE IS KNOWN FOR HAVING PROBLEMS WITH THE CIRCUIT BOARD IN THE HANDLE.YOU'LL NOTICE THAT MODELS THAT CAME AFTER THAT HAD SLIDING SWITCHES. UNFORTUNATELY THE NEW HOSE DESIGN WON'T WORK ON YOUR MACHINE BECAUSE THE CIRCUIT BOARD INSIDE THE MACHINE WAS CHANGED TOO.AERUS MAY OR MAY NOT STILL MAKE THE PARTS YOU NEED. OTHER WISE LOOK ON E-BAY FOR A NEW HOSE.
ELECTROLUX FOOLISHLY REPLACED IT'S FLAGSHIP STEEL MACHINE WITH THIS DESIGN...A FEW YEARS LATER ALL THEY HAD WORTH SELLING WAS THEIR NAME, HENCE THE NEW NAME AERUS.
Mar 28, 2008 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
147 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
