Question about Minolta Photography
I have a Minolta x700 that has not been used in years. I replaced the batteries and the lights all work; however, the film advance lever will not work nor will the shutter release. I see that two years ago people had this same problem, but the suggested solutions no longer appear. Trying to trust my failing memory, it seems like one of my Minolta cameras (I had an older model) had a second battery somewhere, but I see no reference to a second battery in the literature I can find. Other than replacing the batteries I have not done anything to "fix" the problem.
    Brigadier General:
  • 3,006 Answers
Unused cameras tend to seize up: unless they're used regularly the internal lubricant films dry out and gum up and the fault you describe is typical of this.
As a professional repair, it's totally uneconomical and due to the scarcity of spare parts it's highly unlikely that you'll find any professional who will touch your camera as things may break during disassembly.
All you can do is to try and strip and repair this yourself. A full stripdown will be unrealistic, but with a bit of care and caution it's often possible to free up enough of the camera to get things moving again. I don't know of any free repair manuals, but you won't go far wrong by carefully removing the baseplate (watch out for the soldered wires to any electrical contacts) and trying a bit of manipulation. Use something clean and lint free to clean off gummed up grease (not cotton buds), and replace with a smear of light grease. Don't go anywhere near a WD40 can and don't mistake vaseline (petroleum jelly) for grease!
Removing the camera top plate is real "here be dragons" territory. To do so needs far more care and often special tools and the electronics underneath the top plate have to be carefully moved to access the mechanical parts. Doing so often irreparably damages them.
Posted on Sep 08, 2010
Testimonial: "Very thorough answer which is reasonable. There is never anyway of know, but since when I put the camera away it worked. Thanks!"
I recently got a minolta x700, it appeared to be working, the shutter would fire and the film advance lever was working fine even without film or batteries, then when i was going through the functions
What happened when your were testing out batteries and changing the modes? Your question is unclear.
I look forward to hearing a followup question.
Thanks,
BAX
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
atdlee@netzero.com
Film advance stuck and metering problem on Minolta X700
Hi, i have the same problem, do you fix it?, can you give me the solution please?
Thanks, my mail is dg_alex_vargas@hotmail.com
Jan 27, 2010 | Minolta X-700 35mm SLR Camera
Film Advance levar wont work. Milnolta x-700
The Minolta X-series (X-300/370, X-570, X-700) were known for this issue. Two capacitors under the top and bottom covers go bad over time. They prevent the shutter from releasing, so you cannot wind to re-**** the shutter. If you're handy at these things, you can buy the caps, remove the covers, solder in the new caps, and be fine. This issue is well known and you can find instructions on the web. Or you can send it in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at $58 incl return postage. Look him up on the web.
Aug 05, 2009 | Minolta X-370S 35mm SLR Camera
Film Advance won't work on Minolta X-700
changing the batteries have no effect on film transport, just a coincidence. take the bottom cover off and check the white plastic gear on the film take up side of the camera. if it is broken your X700 may not be repairable as no new parts are available.
push the re-wind button in and try to charge the shutter again. remove film first. if it still just goes part way then a gear is stripped. try to find a camera repair shop that may have good used parts available.
Jul 18, 2009 | Minolta Photography
Film Advance lever stuck
When you press on the shutter release does it "click"? A few hard taps with the end of your finger onto the shutter reelase button may unjam it if it is stuck...
Jun 15, 2009 | Minolta X-370S 35mm SLR Camera
Minolta x700 winder broken off camera
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
May 22, 2009 | Nikon FM10 35mm SLR Camera
My daughter just got a used Minolta 700-X. We are trying to load the film, but the advance lever won't advance to load the film after we put it in. Can you help?
Are the batteries good ,is the battery cap and contacts clean? Can you fire the shutter? Move select off auto and try to release the shutter. If the shutter fired off auto and will not fire on auto with good batteries. Either the shutter or flex circuit must be replaced. There are no new parts avail. for the X700.
One other item for the X700. check to see if the shutter fully traveled on the last shot.
Dec 07, 2008 | Photography
35 mm, Minolta X700
Is the re-wind button stuck in? If so it can be released by moving the take-up sprocket manually. If that did not work there is a broken take up gear. This was a common problem with the X700, a white plastic gear was used at the bottom of the take up spool mechanism that just was not strong enough especially when trying to get just one more shot from the roll of film. No new parts are available.
Sep 20, 2008 | Photography
Photography Logo
371 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
