Question about JVC RC-EX25 Radio/Cassette/CD Boombox
Lid isn't fitting properly and it says open when it isnt
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 255 Answers
Try to take it out and put it back in
the axle is off
Posted on Sep 07, 2010
When I tried to open the clear bin to empty it, the bottom did not drop open and now I can't push the cyclone down. What do I need to do to fix this?
I can't be specific without knowing your model but the crud and gunk that collects inside the dirt bin can restrict the door from opening and closing properly. If the door isnt closed properly the dirt bin may not fit back into the vacuum.
Jan 20, 2017 | Vacuums
P0321 and p0322 on a 02 passat
Trouble Code: P0321
Ignition/Distributor Engine Speed Input Circuit Range/Performance
Possible Causes:
Engine speed sensor has failed or is damaged.ECM has failed.Sensor wheel is damaged or doesn-t fit properly.Sensor wheel spacer isn-t seated properly.
Trouble Code: P0322
Ignition/Distributor Engine Input Circuit No Signal
Possible Causes:
Nov 18, 2012 | Volkswagen Cars & Trucks
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
Error message dE
hello there and thank you for choosing fixya
dE - Lid door open error Lid /door isnt fully closing or is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board
Jul 28, 2011 | GE Energy Star WCVH6260F Front Load Washer
The magenta isn't printing correctly, and the printer keeps telling me to remove tape from the magenta cartridge. There isn't any tape on it. I've tried resetting it several times.
Its sounds as though the printer isnt picking up the cartridges properly, try removing it and cleaning the contacts on both the cartridge and the printer
May 05, 2011 | Dell 3130cn Color Laser Printer
Our washer is filling with water but will not run the cycle after it fills. We were able open and close the lid and it would start but now it only fills with water...Please help!!!
the lid switch is buggered the lid can be open while its filling but when it goes to start washing the lid needs to be shut so the lid switch isnt working so the machine thinks the lids open.
Jan 05, 2011 | Maytag Washing Machines
MY 99 BMW 318 SERIES CONVERTIBLE ROOF WONT OPEN MOTORS ARE WORKING MIGHT BE THE RAILS ? HOW EASY TO FIX
there is an inhibitor switch built into the boot lid if it is faulty or boot lid isnt closing properly roof wont fold up (or down)
May 13, 2010 | BMW 3-SERIES CONVERTIBLE
Printer lid open light is coming on when printer lid is closed
The printer lid error can appear if any of the following are true:
- top lid is open
- rear duplexer or flat panel is not installed correctly
- cartridge bay area door is open
All of these conditions are detected by a series of sensors or circuits in the printer design so with regard to the lid and cartridge bad door you need to make sure that nothing has broken off that closes the switch.
I'd lay odds that it's most likey the rear panel/duplex unit. I'd recommend taking this out as per the manuals instructions and then reinserting it, carefully so that it fits in place properly.
Hope that solves your problem.
Martin
May 19, 2009 | HP Officejet Pro K850 InkJet Printer
1997 BMW 328i convertible
The problem is that your roof(SOFT TOP) lid isnt closing properly. If you open the roof lid you see there is a button on one of the latches that tells the car that the roof is securely closed if your roof lid is not secure the trunk wont open. To test this press down on the roof lid and the try to open the trunk.
Jun 15, 2008 | 1997 BMW 328
Idesit dishwasher
it sounds like the element isnt working properly.locate the element connections by removing the lower kick panel and turn the unit on to the drying cycle.use a volt meter and check the voltage.if you have voltage there than turn the circuit breaker off remove the wires to the element and check with the meter for continuity,let me know.
Nov 10, 2007 | Indesit 24 in. D63 Free-standing...
JVC RC-EX25 Radio/Cassette/CD Boombox Logo
23 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
