Question about Hayward 1 Hp Max - Flo Swimming Pool Pump
1 hp hayward pump and can get impellar off - Hayward 1 Hp Max - Flo Swimming Pool Pump
    President:
  • Hayward Master
  • 1,378 Answers
Power off - lock the shaft at the end where the electrical is hooked up. Spin the impeller off counter-clockwise.
John
Posted on Sep 07, 2010
How do I remove impeller from motor? Is there bolt or does it screw off? It appears head of bolt is sheared off.
The impellar spins off counterclockwise on most pumps. The hard parts are holding the motor shaft from rotating and finding a way to grip the impellar.
Gary
Jul 24, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Hello, I have a powerline Hayward swimming pump. With a A.O.Smith motor. Now wil chance the two bearings of the motor but i can't lose the impeller SP1707C. What is the best way to relaese the...
I believe that on the back of the motor shaft, there are either wrench flats or a screwdriver slot.
Use the appropriate tool to hold the shaft from rotating and grip the impellar with your hands or a strap wrench or other device and unscrew it.
Gary
May 01, 2011 | Hayward IMPELLER 3/4 HP, SP1707C
My Pentair WF-26 1.5 HP just started emitting a loud "whine" detectable above the regular pump noise. Looking through the window into the debris basket the water also looks more frothy than...
The loud "whine" you hear, does it sound like its a metal kind of "whine"? There are a couple of things it could be. Your impellar may have debris caught in it and to properly check and clean the impellar you will need to open up the pump and remove the diffuser and check/clean as needed. You can sometimes remove the basket and try to feel your way with a couple of fingers to the impellar but your only able to reach 10% of it. Whisperflo is an outstanding pump but very notorious for debris getting stuck in the impellar and the impellar breaking easily because it is plastic. If you have ran the pump without prime/no circulation you can easily have caused heat damage to the impellar. The other thing to check is the motor. Although it is only 2 1/2 years old the motor still could be going out. The bearings are the top noise makers when a motor is going bad. You will still have normal suction/circulation it will just be really loud when the motor runs each day.
I hope this helped. Please don't hesitate to submit any further questions you may have. I would be glad to help.
Dec 07, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Ihave a hayward 1hp inground pool pump and can not get the impellar off
you will need to hold the motor shaft at the back of the motor with either a 7/16 open end wrench, or either armature tool. You can then use a closed face impeller wrench to remove it. Make sure if there is a screw in the center of the impeller to remove it by turning clockwise.
Sep 06, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
John
Sep 06, 2010 | Hayward Pool & Spa
Motor humming will not turn
You can undo the bolts that are holding the motor to the pump. That will let you spin the impellar of the pump .. Please withdraw it slowly and observe how the extra pieces fall out because if you get them in wrong the pump will not work correctly, While you have it apart , try and spin the impellar and switch the motor on , seeing if it will run if you hand start it .. if it will not run , then you probably need a new motor .. Most pool shops can test the motor for you to confirm that .
Please Vote !
Jun 05, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Low pump pressure
Or blocked.
Have you used pool 'O' ring grease on all 'O'rings - tipped water from bucket on all pipe joins on suction side to see if blows bubbles?
Jul 12, 2009 | Hayward 1.5 Hp Northstar High Performance...
Jandy jhp .75 hums when you turn it on does not pump
It sounds as if motor is spinning and pump is free so the impellar must not be attached to the motor shaft. There is a set screw on the impellar to hold it to shaft or the pump impellar could be cracked. Only way to tell is take the impellar housing off.
what kind of motor or pump? Hayward, pac flo?
May 28, 2009 | Plumbing
My Northstar 1.5 hp is developing less than 10 psi. It occasionally squeals briefly when started. Otherwise it runs smoothly. The pool vac barely moves at all, even with the skimmer turned almost...
Hi George It's your impellar or bearings you need some tools for the bearings but if it is impellar you can do this I would suggest you just take it in and rebuild hole thing as you will be better off in the long run.
THANX FOR USEING FIXYA
RATE ME
Apr 27, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward 1 Hp  Max - Flo Swimming Pool Pump Logo
107 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
